Keysyrider Posted March 16, 2014 Posted March 16, 2014 Does anyone know what the "Mic In" plug is for on the Zumo 660 wiring harness? I need to listen to my Garmin which is what the "Audio Out" connector is for, right? I think it is for use with a cell phone or Bluetooth but I just want to make sure.
Sexagenarian Posted March 17, 2014 Posted March 17, 2014 interestingly, other than the reference to the 'microphone' jack on the "getting started" page, I could find no other reference to it or anything else about it, when doing a quick skim of this manual: 660 Manual
Guest tx2sturgis Posted March 17, 2014 Posted March 17, 2014 Plug-in microphone for the sunvisor in a car? For voice commands? Just guessing.
RedRider Posted March 17, 2014 Posted March 17, 2014 Microphone from your helmet. Allows you to have your Zumo hard wired to your bike and to talk on the phone over your wired headset/microphone. Buddy Rich cable should work for this, although, I'm not sure. The BR cable was designed for the Zumo 550. Assume it will work with the 600/660. Check with Buddy. RR
djh3 Posted March 17, 2014 Posted March 17, 2014 Buddy Rich makes a cable and air rider or someone. I got a used one a fellow bought and never installed. But I have yet to get the Bluetooth part of the mic to work right. If the GPS has Bluetooth you can connect your phone and then use the intercom (somehow I have yet to figure it out or get good directions) I have used mine in a parking lot to call wife but once I got to about 20mph she said there was to much noise. Have not tried it since.
Keysyrider Posted March 19, 2014 Author Posted March 19, 2014 Yes, the mic plug in is for using with a Bluetooth setup when you have a phone. Just taped it off and now I'm good to go. Thanks
