alvald83 Posted March 14, 2014 Share #1 Posted March 14, 2014 I have an engine squeal that squeals only when I am on the throttle. as soon as I let off the throttle it goes away. I am familiar with the speedo squeal and this is not that. This is a constant, as long as I am on the throttle. Any ideas? Link to comment Share on other sites More sharing options...
rable Posted March 14, 2014 Share #2 Posted March 14, 2014 I think you are running over that Hogs tail that you are behind:rotf: Link to comment Share on other sites More sharing options...
Venturous Randy Posted March 14, 2014 Share #3 Posted March 14, 2014 Could you possibly have an exhaust leak that could be squealing when you give it throttle? RandyA Link to comment Share on other sites More sharing options...
MiCarl Posted March 14, 2014 Share #4 Posted March 14, 2014 Possibly a sticking starter clutch. The starter will really sing if the engine is driving it. Link to comment Share on other sites More sharing options...
dacheedah Posted March 14, 2014 Share #5 Posted March 14, 2014 shaft splines been greased? Link to comment Share on other sites More sharing options...
Marcarl Posted March 14, 2014 Share #6 Posted March 14, 2014 Check the air-box, make sure that everything is there and in place and nothing has worked it's way into a carb throat. Link to comment Share on other sites More sharing options...
bongobobny Posted March 14, 2014 Share #7 Posted March 14, 2014 Don't suppose you could capture a sound bite for us to listen to?? Link to comment Share on other sites More sharing options...
Yammer Dan Posted March 14, 2014 Share #8 Posted March 14, 2014 Sticking starter button!! Link to comment Share on other sites More sharing options...
alvald83 Posted March 15, 2014 Author Share #9 Posted March 15, 2014 Im going to fool around with it tomorrow using some of your suggestions. Link to comment Share on other sites More sharing options...
GeorgeS Posted March 15, 2014 Share #10 Posted March 15, 2014 Sounds, like you have a new one !!! ( pun intended ) Never heard that one before ??? Link to comment Share on other sites More sharing options...
