TheCoffsKid Posted December 2, 2013 #1 Posted December 2, 2013 (edited) Hi, The next challenge for me will be to mount a tacho on my 2006 tour Deluxe. Since the speedo is very art-deco in style I want to attempt to keep that style, and I will be using a Suzuki M109R tacho. See excel attachment. The first job will be to remove the parts labelled "A" and "B". Then I will remove the cowl from the RSTD speedo, and if the schematics on the parts CD are correct, most of the space underneath will be unused. If this is correct then I won't have to modify the Suzuki tacho any more except to remove the wires that I don't need. I will then, very, very, very carefully cut an opening in the top of the RSTD speedo and mount the Suzuki into the gap. Then it will just a matter of securing one to the other, and wire everything up. Every time I do something I will take photos and post. Cheers, Edited December 2, 2013 by TheCoffsKid forgot the attachment
TDbiker Posted December 2, 2013 #2 Posted December 2, 2013 I'll be following this one... Looks like it'd be a nice match to the speedo.
TheCoffsKid Posted December 3, 2013 Author #3 Posted December 3, 2013 I took off the RSTD instrument cluster (meter) and there isn't that much room , what with the handlebars and wiring looms. So it will be out with the playdough and remount the cluster, then pull it off and see how much room there is and where. Question without notice:- As I will only need 4 wires of the M109R tacho, can I get rid of the printed circuit board? Cheers,
1joeranger Posted December 4, 2013 #6 Posted December 4, 2013 Came across this a while back and thought it was very cool!! http://www.classicinstruments.com/seriesdetail.aspx?SeriesCode=-
TheCoffsKid Posted December 6, 2013 Author #7 Posted December 6, 2013 they are very cool, and if I was building my own bike I would use something like that or something similar. there is a lot of cool looking stuff out there. I have purchased another instrument cluster housing so I can continue my challenge. probably won't arrive until new year, but progress is being made....slowly Cheers,
TheCoffsKid Posted December 11, 2013 Author #8 Posted December 11, 2013 Hi, I have removed parts marked "A" & "B" and this can be seen on the attachment. Then I removed part marked "C" The hole where "C" was will have to be filled in; bit of creative thinking will need to be applied; it will be under cover so maybe not..will see when I get further along. Photo of tacho on instrument cluster just to see how it looks. If I can adapt the tacho main cover that would be ideal but if have to use the full cover it will mean moving the tacho towards the rider. If I have to move the tacho, removing "C" would have been a waste of time. I have another main instrument cluster cover so if I have to move the tacho towards the rider I would try and use that so it would look like 2 instrument clusters. Don't hold back tell me what you think and how am I going. have to send two attachments; one with this post and another on the next post Cheers, TCK
TheCoffsKid Posted December 17, 2013 Author #10 Posted December 17, 2013 (edited) Hi all, little bit more progress. have mounted the tacho onto the instrument cluster cover, and it doesn't look that bad. It sits a little higher that I would like but I cannot cut into the PCB, unfortunately. Still needs some work to get it to sit right, but I am going for a ride in the next few days, so we'll see. The grey loom out the back will eventually go as I think I only need 4 wires. As soon as we get the tacho to work we'll get rid of the extra wires, put the remainder in some heat shrink wrap, drill a whole in the cover and slide it through a rubber grommet. Any comments appreciated. Cheers, TheCoffsKid Edited December 17, 2013 by TheCoffsKid bad spelling
1joeranger Posted December 17, 2013 #11 Posted December 17, 2013 I was gonna suggest drilling a hole in the cover and hiding the wires, but you already are contemplating that, so I will just sit back and admire!! Really lookin good!
TheCoffsKid Posted January 3, 2014 Author #12 Posted January 3, 2014 Just put down my $100 deposit for the Rivco centre stand; I had to get up at 0400 but at least the dog was happy! Bike goes in for a service in two days so the auto elec will try and get the tach to work; if he does its onwards and upwards. Cheers,
RAm5700 Posted January 3, 2014 #13 Posted January 3, 2014 TheCoffsKid said: Hi all, little bit more progress. have mounted the tacho onto the instrument cluster cover, and it doesn't look that bad. It sits a little higher that I would like but I cannot cut into the PCB, unfortunately. Still needs some work to get it to sit right, but I am going for a ride in the next few days, so we'll see. The grey loom out the back will eventually go as I think I only need 4 wires. As soon as we get the tacho to work we'll get rid of the extra wires, put the remainder in some heat shrink wrap, drill a whole in the cover and slide it through a rubber grommet. Any comments appreciated. Cheers, TheCoffsKid Good project. The way I ride I would like a tach. and have been contemplating adding one.
TheCoffsKid Posted February 6, 2014 Author #14 Posted February 6, 2014 The RSTD has been in the workshop to be given the once over to make sure everything is ok; change all fluids, clean/change all filters; tune up etc. That's all done, and as well the tacho works!!! Will send photos shortly. The lights have all been wired correctly and adjusted. The levelling links have been installed and work as advertised. Next up is the R1 brake conversion from Earl, then the bigger tank and whilst that is being done the Dyna3000. Won't be much else to do soon except ride the thing. To paraphrase one of our early quiz show hosts: happy riding customers!!
Trader Posted February 6, 2014 #15 Posted February 6, 2014 you do know you can attach pictures without embedding them in a program like excel or Word right? I know I am uncomfortable opening up attachments from an open forum.
Bert2006 Posted February 7, 2014 #16 Posted February 7, 2014 Wonder if that would fit in the space left from removing the cassette deck on a RSV?
TheCoffsKid Posted February 7, 2014 Author #17 Posted February 7, 2014 If you look at the attached photos you will see that there is not much that you need to keep. Just keep the left hand piece, cut loose the wires and make an adapter plate, and you should be laughing. cheers
coop Posted February 8, 2014 #18 Posted February 8, 2014 can you please post a picture of the face? I can't open your xl attachment. I'm interested in putting a tack on mine and haven't found anything that will mach the speedo. thanks bob
coop Posted February 8, 2014 #19 Posted February 8, 2014 Just found a picture on line.... that would look perfect sitting on top of our speedo. Nice choice kid. I see some available on Ebay for 300.00 Might pick me one up Bob
TheCoffsKid Posted February 9, 2014 Author #20 Posted February 9, 2014 cheers, I spent many, many hours on the net trying to find a tacho that would match the style and shape of the rstd instrument cluster, and this was as close as I could get. When I have used it for a few months and I an happy with how it works I will try some mods.
TheCoffsKid Posted February 25, 2014 Author #21 Posted February 25, 2014 Hi, Photos of tacho working. Will leave as is for a few months then if all ok will look to integrate it a bit better. cheers,
coop Posted March 11, 2014 #22 Posted March 11, 2014 I like that tach Any pic's that show the whole speedometer....I'd like to se better how it looks sitting on there. Bob
TheCoffsKid Posted March 11, 2014 Author #23 Posted March 11, 2014 See attached next step will be to see if I can move the pcb so I can lower the tacho into the oem instrument cluster...will go and see my computer tech. cheers, gd
coop Posted March 13, 2014 #24 Posted March 13, 2014 hey thanks for those pictures. I'd be interested in trying to mount it flat on the speedometer case. maybe trim up the tach case to remove the bottom side of it's case. template the contour of the top surface of the speedo case and shape the tach case to match. bob
TheCoffsKid Posted March 15, 2014 Author #25 Posted March 15, 2014 Coop, I will start a new thread on the TD tech forum called "M109R tacho" I will get all my photos in order and go through everything I did. cheers, gd
