Lassesand Posted October 17, 2013 Posted October 17, 2013 (edited) My -84 XVZ12 is behaving strange. When cold the idling rpm is 1000. When warm it usually takes some second for it to drop from 2000-1500 down to 1000. If it's really cold ( 0 deg Celsius) the idling can get stuck at 2000 rpm and when not so cold (eg 7 deg Celcius) it can be 1500 rpm and in both cases does not drop unless you shut off the bike and start it again. I sometimes get the impression that it runs on three cylinders but I'm not really shure it's ignition related or carb (or both). I did change all the carbs last year but that didn't cure the problem so I should say that it's more likely to be ignition related. I have had the Ignitech box installed all the time. I don't expect that you can give me a direct answer to this but someone perhas have some sort of idea what to look for? A check list perhaps. Edited October 17, 2013 by Lassesand added a link
MiCarl Posted October 17, 2013 Posted October 17, 2013 Unfortunately there are a lot of things that can cause a hanging idle: + Poor compression on one (or more) cylinder + Idle circuit in one or more carburetors dirty or out of adjustment + Poor sync + Intake leak
pmelah Posted October 18, 2013 Posted October 18, 2013 im no expert but i would say dirty out of adjustment carbs and poor sync i have that problem to but once it does warm up it gets better
Yammer Dan Posted October 18, 2013 Posted October 18, 2013 All the above. My 85 did this after I pulled it out of that garage in Ohio. Took some serious Sea-Foam before it settled down. Done a Sea-Foam Soak??
Marcarl Posted October 19, 2013 Posted October 19, 2013 I would say do a sync from scratch and then go from there. Let us know how you did or if you have more problems.
