bikerjohn Posted August 20, 2013 Share #1 Posted August 20, 2013 Can someone who has gauges installed tell me what the normal operating Water Temperature should be? I just installed and would like to know what is out of range Thanks Link to comment Share on other sites More sharing options...
V7Goose Posted August 21, 2013 Share #2 Posted August 21, 2013 200 - 210 most of the time, should never get over 240. Goose Link to comment Share on other sites More sharing options...
foyerboy Posted August 21, 2013 Share #3 Posted August 21, 2013 200 - 210 most of the time, should never get over 240. Goose Ditto..... Link to comment Share on other sites More sharing options...
V7Goose Posted August 21, 2013 Share #4 Posted August 21, 2013 You will notice the engine runs a little cooler on the hottest days. When the thermostat stays wide open, the engine can run as low as 195 or even 190 out on the road. By contrast, below 20F outside, the engine will constantly swing between 165 and 200 as the thermostat starts to crack open and then the coolant is cooled faster than it can shut again! Goose Link to comment Share on other sites More sharing options...
Jimbob66 Posted August 21, 2013 Share #5 Posted August 21, 2013 You will notice the engine runs a little cooler on the hottest days. When the thermostat stays wide open, the engine can run as low as 195 or even 190 out on the road. By contrast, below 20F outside, the engine will constantly swing between 165 and 200 as the thermostat starts to crack open and then the coolant is cooled faster than it can shut again! Goose Below 20f ? I'm not even certain my Venture starts when its that cold! Link to comment Share on other sites More sharing options...
Bert2006 Posted August 21, 2013 Share #6 Posted August 21, 2013 Sorry, not trying to hijack thread, but what type/brand temp guage would you recommend for the 2nd gen. http://www.visitedstatesmap.com/images/BCMBNBNSONPEQCsm.jpg Link to comment Share on other sites More sharing options...
Jactana Posted August 21, 2013 Share #7 Posted August 21, 2013 200 - 210 most of the time, should never get over 240. Goose I have a "Ponch Gauge" package and that's consistent with mine. Cheers. Ron Link to comment Share on other sites More sharing options...
Steel Horse Cowboy Posted August 21, 2013 Share #8 Posted August 21, 2013 (edited) If you are an Old School gauge watcher and think that anything above 190* is getting hot, don't install a temperature gauge. When I first installed mine and saw the temp get up above 195* I took the gauge back to the Advance Auto and made them replace it under warranty. When I put the new gauge in and it done the same thing, I got worried and took my themostat out thinking it was stuck closed. The thermostat was fine, so I checked a lot of other things thinking maybe the fan wasn't working or the radiator might be stopped up or a few other things. Everything checked out good. I then called the Cycle shop where I get all my parts and he said that 190* - 210* was normal temp. I also looked on the site here and found some threads that confirmed this. The other day mine did go up to 230* in stop and go traffic. So, unless it gets up around 240* or the temp light comes on don't worry about it. That's easy to say but hard to do if you are an Old School gauge watcher. Here's a link to the gauges I installed http://www.venturerider.org/forum/showthread.php?t=63928 V7Goose it's good to see you posting again. C.R. Edited August 21, 2013 by Steel Horse Cowboy Spelling, add link Link to comment Share on other sites More sharing options...
V7Goose Posted August 21, 2013 Share #9 Posted August 21, 2013 Sorry, not trying to hijack thread, but what type/brand temp guage would you recommend for the 2nd gen. Just about any gauge will work, but I am partial to mechanical gauges instead of electric. There are a number of options for mounting, but on a bike, just about all of them need the smallest gauges you can find (LESS than 2"). Generally just go to the local discount auto parts store and buy the cheapest three-gauge set you can find. If you are going to mount a temp gauge, you really should do the oil pressure too. I prefer a digital volt meter, but the three gauge sets are a good buy even if you throw the volt meter away. See the tech library for intimate details on installing gauges. Goose Link to comment Share on other sites More sharing options...
bikerjohn Posted August 21, 2013 Author Share #10 Posted August 21, 2013 Thanks for all the replies!! Mine is around 210 -215 in the Texas heat. Also i used th write up by Freebird but I used the spark plug fouler instead of the brass fitting from lowes. Had to drill the opening bigger but it worked great. Link to comment Share on other sites More sharing options...
