OrlinEngh Posted July 9, 2013 Share #1 Posted July 9, 2013 I have no tail light, I put in a inline fuse for the signal fuse to check to see if my other problem was solved before I went threw putting in the new fuse block. Now everything works but the brake light using the foot or hand brake, The bulbs are good, is there a fuse just for the brake light or a relay, I checked the conections under the seat and the ones that I could find. Orlin Link to comment Share on other sites More sharing options...
maknak Posted July 10, 2013 Share #2 Posted July 10, 2013 Here is a great wiring diagram i got off this site by Gary Dinges maybe it will help http://sdrv.ms/14Hqx7f Link to comment Share on other sites More sharing options...
reddevilmedic Posted July 10, 2013 Share #3 Posted July 10, 2013 I chase running and brake light issues all the time. I have skydocs fuse kit. normally, it comes down to the cmu being resoldered...for me. also, check the ground at the taillight. Link to comment Share on other sites More sharing options...
dingy Posted July 10, 2013 Share #4 Posted July 10, 2013 I have no tail light, I put in a inline fuse for the signal fuse to check to see if my other problem was solved before I went threw putting in the new fuse block. Now everything works but the brake light using the foot or hand brake, The bulbs are good, is there a fuse just for the brake light or a relay, I checked the conections under the seat and the ones that I could find. Orlin As mentioned, brake lights are routed through the CMU. The signal fuse probably protects that circuit. Horn is on same fuse, check it. Also, follow link below to put bike info in your header, it really makes it easier for us to help you without having to open your profile to see what bike you have. Hard to remember them all !! http://www.venturerider.org/forum/showthread.php?t=58880 Gary Link to comment Share on other sites More sharing options...
dingy Posted July 10, 2013 Share #5 Posted July 10, 2013 Here is a great wiring diagram i got off this site by Gary Dinges maybe it will help http://sdrv.ms/14Hqx7f Most all of the Venture wiring diagrams are on this site. http://www.venturerider.org/forum/forumdisplay.php?f=68 or, RSV's http://www.venturerider.org/forum/forumdisplay.php?f=91 Gary (Dinges) Link to comment Share on other sites More sharing options...
OrlinEngh Posted July 10, 2013 Author Share #6 Posted July 10, 2013 This is my 87, sorry I didnt put that on here, I checked for current going down to the foot brake switch and I dont have any in the yellow wire the other two have current, I jumped the yellow and black wire and the blue and white wire on the back of the CMU and got brake light but it stays on, Is there a way to by pass the CMU to get the brake light to work untill I can get this one fixed or a new one. Orlin Link to comment Share on other sites More sharing options...
dingy Posted July 10, 2013 Share #7 Posted July 10, 2013 I attached a picture of the back of a Royale type CMU showing jumper positions to bypass reed switches. Not sure if this will work for your issue though, but it may. Gary Link to comment Share on other sites More sharing options...
Flyinfool Posted July 10, 2013 Share #8 Posted July 10, 2013 Once you get the CMU out, it is only another 20 minutes to do the repair soldering. Link to comment Share on other sites More sharing options...
OrlinEngh Posted July 10, 2013 Author Share #9 Posted July 10, 2013 What do you look for to resolder, never had one of these apart untill last night, All looked good except there are three cooper looking coils and one of those isnt as clean as the other two. Is there away to check the CMU to make sure that it is what the problem is. Orlin Link to comment Share on other sites More sharing options...
Flyinfool Posted July 10, 2013 Share #10 Posted July 10, 2013 There should be 4 of those copper coils. It is the ends of those coils that are often an issue. Just resolder all of them. Also resolder all of the connector terminals. Because of the number of issues that you have it is more likely that your issue is the ground connector pin. To do the resolder, you want to add a bit of flux made for electrical, NOT plumbing. Heat the joint enough to melt the solder and add a bit of fresh solder. I like to use the silver solder from Radio Shack and the Flux. Use a small soldering pencil, 40W MAX. If you ever plan to install LED brake/tail lights or an HID headlight. Now would be a good time to jumper the board while you have it out. Link to comment Share on other sites More sharing options...
