Today it was over 90 when I went for a ride on my 84 venture. It has always ran right at or above the first line at the bottom1/4 of the temp gauge,but today I hit construction and set in traffic not moving for 5 to 10 minutes and the gauge went up to about 2/3 high. Is this normal? It cooled right back down when I got to rolling again.
That's the way mine is too. Fan will kick on just below the red line.
You'll know the fan kicked on because all the skin will fall off your legs.
Quite normal, but temp quage will go higher under similar circumstances riding two-up. 1983 models read high, but never boils over if cooling system is clean, full, and t-stat working. Later models don't read nearly as high, and cooling fan can remain on when key is shut off.
-Pete, in Tacoma WA USA
'83,88
As said, all sounds normal with everything works as it should on a 1st gen.
There is one more thing you can take a look at that "might" help a bit if it needs cleaned up.
Pull the radiator cover and take a look at the radiator itself. Mine was cleaned and tested a couple years ago but when I had the cover off there was a LOT of dead bugs, road debris and some minor damage to the fins on the cooling core. A lot of blockage.
I ended up loosening the radiator and using a water hose to softed up the dead bugs and then used a compressor to blow them out from the backside. Then combed the fins out to straight again I did get some improvement on the cooling.
Just one of those things that need to be looked at once in a while.
I have seen where some has hooked up a switch to turn the fan on if they wanted to, but it still worked in automatic. Does anyone have a clue how they have done this?
ground the wire from sensor to a switch and leave factory terminal hooked up. when you flip switch it turns on fan. just like the sensor would work for factory setup. its the blue wire on a 83 right front thermostat housing.
I changed my switch to one that turns the fan on at a lower temp. The fan comes on with the gauge just a little above half and runs less than a minute. I also took out about 20oz of the 50/50 coolant and replaced it with distilled water and water wetter, it seems to stay cooler and cool down faster.:cool10:
