Cowboy Posted September 3, 2012 Posted September 3, 2012 Buddy has a 2006 RSV with a 4 pin wiring harness, He is wanting to pull my Bushtec trailer that has a 6 pin. Does anyone no of a converter or should I just tell him to order the harness from Bushtec? Anyone with a sugguestion? Thanks
Eck Posted September 3, 2012 Posted September 3, 2012 (edited) I do not know of any conversion plug that would work.. BUSHTEC HARNESS Green Tail lights Green Blue Brake Blue Brown Left Turn Brown Yellow Right Turn Yellow Black Ground White Interior Light Black It is normal Bushtec procedure to connect the black wire in the Bushtec harness with the green wire in the Bushtec harness to the green output wire from the relay. If you are connecting a trailer other than a Bushtec to the relay, use the above chart for relay output colors and functions and cross reference with color code and function of your trailer wiring. NOTE: If your trailer has a four wire electrical harness, a trailer light converter will be required in ADDITION to the Electronic Relay Isolator package and is not included with the hitch package. Edited September 3, 2012 by Eck
