Tour Deluxe Posted January 22, 2008 Posted January 22, 2008 Does it matter what type or brand of coolant I use in my RSTD. A friend of mine tells me to use the honda coolant because it will not damage the water pump (Contains low or no silicate). Owners manual just calls for regular 50/50 coolant. What are you folks using ?? Thanks: Will
M61A1MECH Posted January 22, 2008 Posted January 22, 2008 I always used Honda motorcycle specific low silicate coolant in my 98 Royal, put 96k on her before I bought my Venture. Never had any problems and always heard from what I consider reputable sources that regular 50 / 50 mix auot type coolant is bad for motorcyles cooling systems. For my monry I would stick with the Honda or Yamaha coolant.
Tour Deluxe Posted January 22, 2008 Author Posted January 22, 2008 Thanks Steve I appreciate the reply.
hipshot Posted January 22, 2008 Posted January 22, 2008 somewhere, here on this forum, someone stated that any coolant specifically designed for ALUMINUM block engines, is what you need. you might do a search, and find that particular thread. just jt
