alvald83 Posted June 1, 2012 Posted June 1, 2012 My speedo and rpm gauge lenses are hazy and there is a crack in the rpm gauge. Is there a way to replace the clear plastic lenses without replacing the whole gauge unit?
Chaharly Posted June 1, 2012 Posted June 1, 2012 My speedo and rpm gauge lenses are hazy and there is a crack in the rpm gauge. Is there a way to replace the clear plastic lenses without replacing the whole gauge unit? i would assume that effort wise, you'd be better just to replace the whole unit, if you could get ahold of one. If anything, break em out, that'll solve two problems :{P
JohnMidnight Posted June 1, 2012 Posted June 1, 2012 Its a complete thing. You'd save time just getting a complete replacement, or. Knock em out
alvald83 Posted June 1, 2012 Author Posted June 1, 2012 Well, here was my thought. I can have some clear plastic discs made to match the original lenses from the local plastics business. Then, using a side cutting dremel blade, carefully cut the original lens out and adjust the cut out with a half round file. Glue them in with some type of clear glue. I do have a spare unit to practice on.
Dizzle223 Posted June 1, 2012 Posted June 1, 2012 From what I found on line it looks like all the lenses are the same from 83 to 86. I'm sure your method will be less expensive but if you're looking for a stock alternative.... http://m.yamaha-motor.com/PartsViewer.aspx#/Yamaha/XVZ12TK_-_1983/METER/XVZ12TK_(1983_MOTORCYCLE)/METER_(XVZ12TK_-_1983) http://www.powersportsplus.com/parts/detail/yamaha/YP-26H-8353G-00-00.html I have also seen a couple on ebay but I didn't have any luck searching by the Yamaha part #. Hope this helps. Brian
