kwisor Posted May 20, 2012 Posted May 20, 2012 hello all my 99 rsv started to run bad today it acts like it is running out of fuel i have the a/m fuel pump i replaced the fuel filter last week. what it is doing when i cruse at 55 or 60 it acts like i am running out of fuel i hit the throdel and it takes off and runs fine them at cruse speed starts missing again like needs fuel any idea what to look at thanks bumble bee
etcswjoe Posted May 21, 2012 Posted May 21, 2012 Was it running fine before you replaced the filter or is that why you replaced the filter?
Guest scarylarry Posted May 21, 2012 Posted May 21, 2012 I'm lost then...Sure don't sound like a fuel pump and ypu replace filter.. Let one of the experts chime in here
kwisor Posted May 21, 2012 Author Posted May 21, 2012 it was running fine before i replaced the filter it was just time to replace it. and it has ran fine for the last week since i replaced it bumble bee
etcswjoe Posted May 21, 2012 Posted May 21, 2012 it was running fine before i replaced the filter it was just time to replace it. and it has ran fine for the last week since i replaced it bumble bee Did you check your fuel line from the tank to the filter and from the filter to the carbs for leaks or kinks/pinches?
Guest scarylarry Posted May 21, 2012 Posted May 21, 2012 This is what happens when the vent tube is kink...
playboy Posted May 21, 2012 Posted May 21, 2012 This is what happens when the vent tube is kink... Wow hope that was under warranty
Guest scarylarry Posted May 21, 2012 Posted May 21, 2012 Yes very much so and it was from a kink vent line... Kaw did excellent job on taking care of me, over nighted a tank here and was put on the next day...One thing they would not let me keep the old tank...
kwisor Posted May 21, 2012 Author Posted May 21, 2012 i cked the fuel line no kinks did not ck for clog and have not cked vent line i will do that tomorrow
Redneck Posted May 21, 2012 Posted May 21, 2012 (edited) What you are describing in not starving for fuel. If it is starving for fuel at cruise speed then when you throttle it it would just bog down and quit pulling. With a fuel starvation problem the more throttle the worse it will be. What you are describing is more like a flooding problem open throttle is more air to burn more fuel less throttle is less air. It sounds like you have a carb flooding not starving. Edited May 21, 2012 by Redneck
kwisor Posted May 21, 2012 Author Posted May 21, 2012 hello if i have a flooding problem what steps do i need to do to correct it? bumble bee
Redneck Posted May 21, 2012 Posted May 21, 2012 There are a number of things that can cause what you are describing ranging from debris in a needle valve bad fuel water in fuel pluged circuits in the carbs ect. What I would do first is drain the carbs ( screw on the side of each carb at the bottom) open the drains a couple of turns and catch the fuel so you can check for water debris ect. With the carbs empty and the drains open turn on the key and let the fuel pump flush the carbs. A dose of sea foam or b12 may also help.
Condor Posted May 21, 2012 Posted May 21, 2012 Sounds to me like you have a couple of dirty plugs. Toss in another set and then tell us how it's running. Sea Foam will foul spark plugs....
kwisor Posted May 21, 2012 Author Posted May 21, 2012 looked for drains on carbs not sure what thay look like can you show a picture thanks bumble bee
Redneck Posted May 21, 2012 Posted May 21, 2012 I don't have a pic and I'm away from the scooter maybe some one else can give you a picture.
