2nd test ride... new problem
Usually, "backfiring" as loud explosions in the exhaust is caused by either leaking exhaust/muffler connections (allows air into the hot rich exhaust that then combusts) or sticky carb slides or carbs in need of synchronization.
BTW, how do you know it is #3 and #4 backfiring?
I said 3 & 4 because it seems to be backfiring from the right side (as your sitting on it) exhaust. That is also the side there is a possiblity of a loose exhaust pipe connection where the muffler connects with the exhaust header.
