Does anyone know if the heated gear controllers are compatible across the board? I am particularly interested if the First Gear and Gerbings will work?
Warm and Safe and Gerbing are "separate" clothing lines..
You can have a First gear jacket with Gerber pants and the controller will fit and work either piece or any other combination. Only difference is Warm & Safe uses 95 watts of power compared to Gerbings 77 watts of paower..
Not sure if the First Gear products are interchangeable with either Gerbings or Warm and Safe ?? sorry..
  Sleeperhawk said:
Why would you need heated gear? :confused24:
You don't ride anything do you :rasberry::rasberry::rasberry:
LOL, I can understand your confusion, as it does not hang around in one spot long enough to be noticed, unlike the Grey Ghost
