KIC Posted July 12, 2012 Author #326 Posted July 12, 2012 Trader said: Edited to completely rewrite!!!! Hose from #2 carb to vacuum sensor: When it is disconnected from the air box the bike idles wonderfully. When I hook it up the idle jumps to 3200 rpm. I have checked for air leaks around the carbs and that is not an issue. so what is the problem? Why the jump in idle rpm? I ended up just dialing back the idle with those connected to vacuum sensor attached. It seemed reasonable! Have you synced the carbs with the hose connected ?
Trader Posted July 12, 2012 #327 Posted July 12, 2012 guess I shouldn't spend time editing a post in an active thread!!!!! Look at my last post again for suggestion on hose. I just ordered a carbtune....my homemade guage set just bounces too much to be of any use.
dingy Posted July 12, 2012 #328 Posted July 12, 2012 KIC said: Here is the deal.. I sucked on the "existing hose that was connected and the RPMs went high... in fact the throttle was turning by it's self... When I sucked on the "hanging" line it also affected the RPM's but not near as much. I sorta depends on how much you sucked on it. The one attached to the cruise has a large bellows that would need a bunch of air displaced to make a difference. The one attached to the vacuum sensor is an extremely small chamber, so not much air would be displaced. The vacuum sensor will only make a slight difference in RPM's at idle, maybe 100 RPM's. The cruise on the other hand, depends on how good you are. Gary
KIC Posted July 12, 2012 Author #329 Posted July 12, 2012 Trader said: KIC.....is there any chance that hose is the one that goes from the airbox (front left) and "t"'s into the other airbox hose? The one that goes into the tube between the carbs on the "box" on top of the crankcase? http://www.venturerider.org/forum/attachment.php?attachmentid=65439&d=1332797233 see illustration #3 Thanks...but...No... already have that hose hooked up. The hose hanging down is a small hose and is connected somewhere up under the left upper fairing. I couldn't see a similar hose on my 89, so it must be up under there doing something..
Yammer Dan Posted July 14, 2012 #330 Posted July 14, 2012 KIC said: Thanks...but...No... already have that hose hooked up. The hose hanging down is a small hose and is connected somewhere up under the left upper fairing. I couldn't see a similar hose on my 89, so it must be up under there doing something.. Hey Kic ya got orginal plug wires?? If so take the ends apart and clean them. Snip about 1/4 inch off wire to clean up that connection and use flat screwdriver inside plug end to take apart and clean all parts up. Don't loose little parts.
KIC Posted May 31, 2013 Author #331 Posted May 31, 2013 (edited) Just an update as my Grand Princess grows.. She still loves the bike... ( I don't know why it is posting the picture twice) "> Edited May 6, 2016 by KIC
