GolfVenture Posted November 19, 2011 Posted November 19, 2011 Found a good size and long crack in my basement cement floor. It's about 1/8 inch wide and 5 feet long. Could be longer when I get to the other side of the wall and replace that carpet also. I plan on using fix-all to fill inthe gap. My questions is, is there something better to fill in the crack or does it even matter. Also I plan on putting DryLok (Home Depot - Masonry WaterProofer) on the cement floor before laying new wood floor and carpet. Is this a good Idea. My wife believes that mold is a health issue that our medical world has not done much research and really is ignoring this issue. There is paint residue from the initial buildng process on the cement floor, but not much. Or will such a waterproofing cause more of a mildue and mold issue. I was thinking that maybe it is better to allow the cement floor to breath. Thanks for your opinion. PS I do not have a water problem in the basement for I'm on a gently sloping piece of property.
bongobobny Posted November 19, 2011 Posted November 19, 2011 OK My feelings on the subject but I'm no expert. As far as the crack, to do it properly you need to chisel or grind a V trench into the crack to properly fill and bond it. As far as sealing the concrete I think it is a good idea as it will seal moisture from the outside and it should prevent black mold. Myself I would use more of an epoxy sealer like what you would use on a garage floor than dryloc if water in the basement is not an issue, but it will be more costly but a lot more durable...
midnightventure Posted November 19, 2011 Posted November 19, 2011 If you have any mold at all get a dehumidifier. Makes it much more comfortable.
Trader Posted November 19, 2011 Posted November 19, 2011 Home Depot sells a product that is a like a honeycomb of plastic mounted on the back of OSB board. It's not cheap, (I think it was $6 for a 2x2 tile) it lifts the floor up (about 1/2 inch) and allows air to move under the floor.
CaptainJoe Posted November 19, 2011 Posted November 19, 2011 (edited) Does you floor ever get wet... How bout after it rains? if it does i wouldn't cover with anything till you fix the problem with a french drain, down spout extensions, floating basement floor etc... If it stays dry 100% 0f the time... I'd patch crack then install either a ceramic/porclean tile floor, or, dryloc and install one of those floating imatation wood floors over foam...can't recall the name. As the basement is the lowest place of the house, you can bank on where the waters going to go if you ever get a leak. Also, no need for a dehumidifier "IF" you have a cold air return and a vent at each end of the basement . the forced air heater and air conditioner will take care of that . If not, then your gonna be stuck with a dehumidifier... Wood and carpeting can retain water, hence the chance of mold is pretty good. Just my 2 cents... Edited November 20, 2011 by CaptainJoe
jilldwr Posted November 19, 2011 Posted November 19, 2011 I 2nd the Dricore idea. I used the Dricore Product from Home Depot (www.dricore.com) to cover my basement floors. It raised the tempurature of the basement almost 20°f from previous, and stops "wicking" of moisture into the basement reducing dehumidifier cycles. For the crack, I'd use something like Emecole concrete repair kit: [ame=http://www.youtube.com/watch?v=Ohd0b-dzcFY]D-I-Y Concrete Floor Crack Repair - YouTube[/ame] Good Luck!
