Reed Posted September 4, 2011 Share #1 Posted September 4, 2011 I have notsed that my clutch lever has been getting less free play "for say." So I was thinking it is time to change the fluid. Did that about 3000 miles ago. Now it started it again. Went to the steeler, thay changed it again. Sed it didn't look good. I told him I just changed it. He didn't know what the problum is. Sed try it and see what hapens. Is this why the the ventures are having clutch slip??? under power pull the clutch intill it starts to slip. Mine startes to do this with very little pull of the clutch lever. Now after new fluid I can squese the lever about 1.5 inches befour it starts to slip. Is this some thing we should be watching for???? Or do I still have some thing wrong????? Thanks For all the help!!! Link to comment Share on other sites More sharing options...
fishrepair Posted September 4, 2011 Share #2 Posted September 4, 2011 I had the same problem on my 1986 and I doubled up on the clutch spring. About a 1/4 to a 1/2 inch now and it's gone. No slip just get go.I guess that a new spring would do the same but I had another used one in my parts pile. Link to comment Share on other sites More sharing options...
Condor Posted September 4, 2011 Share #3 Posted September 4, 2011 I have notsed that my clutch lever has been getting less free play "for say." So I was thinking it is time to change the fluid. Did that about 3000 miles ago. Now it started it again. Went to the steeler, thay changed it again. Sed it didn't look good. I told him I just changed it. He didn't know what the problum is. Sed try it and see what hapens. Is this why the the ventures are having clutch slip??? under power pull the clutch intill it starts to slip. Mine startes to do this with very little pull of the clutch lever. Now after new fluid I can squese the lever about 1.5 inches befour it starts to slip. Is this some thing we should be watching for???? Or do I still have some thing wrong????? Thanks For all the help!!! Just for the heck of it take the top off the reserve and 'gently' pull the lever in a quarter inch or so. If you should see a slight deformation of the fluid surface, and that means the expansion hole at the bottom of the reserve is clear, and that's good... Also what color was the fluid when you first bled it? And when the dealer bled it?? It should be crystal clear, and if it was, the problem wasn't the fluid. Let us know what you find... Link to comment Share on other sites More sharing options...
RandyR Posted September 4, 2011 Share #4 Posted September 4, 2011 when changing fluid I've found that I must clean the bottom of the reservoir bowl where crud accumulates, otherwise the new fluid becomes dirty again very quickly. Link to comment Share on other sites More sharing options...
Reed Posted September 4, 2011 Author Share #5 Posted September 4, 2011 when i changed the fluid it was a light color not real durty. the hole was open. The steeler sead the fluid looked milkey? That would tell me there is water in it. I dont know? I did clean the reservoir when I change the fluid. Link to comment Share on other sites More sharing options...
Condor Posted September 4, 2011 Share #6 Posted September 4, 2011 when i changed the fluid it was a light color not real durty. the hole was open. The steeler sead the fluid looked milkey? That would tell me there is water in it. I dont know? I did clean the reservoir when I change the fluid. Milky is a term I've never heard before when discribing clutch fluid?? Discolored, black, inky, but never milky... When bleeding the clutch are you using a Speed Bleeder?? When flushing the clutch it's the only way to keep your sanity.... Was any work ever done on the mechanical side... clutch basket etc.?? If not, the problem could be a bad slave where the piston isn't returning all the way due to rusted cylinder walls, but I doubt this due to the bike's age?? OR the clutch spring needs to be beefed up... There's lots of things that could be amiss, but basically you have too much fluid in the hydralic lines for one reason or the other, keeping the clutch pack almost disengaged, and yes it will cause slipping. Link to comment Share on other sites More sharing options...
