winger53215 Posted August 5, 2011 Share #1 Posted August 5, 2011 http://www.ledglow.com/index/ They look pretty easy to install. Everything is plug and play. Link to comment Share on other sites More sharing options...
Hummingbird Posted August 5, 2011 Share #2 Posted August 5, 2011 this is what I used http://ledaccentlights.net/store/index.php?main_page=product_info&cPath=45&products_id=383 Link to comment Share on other sites More sharing options...
winger53215 Posted August 5, 2011 Author Share #3 Posted August 5, 2011 Did you install them on the tank facing down or did you put them a little higher on the tank facing in? Link to comment Share on other sites More sharing options...
MikeWa Posted August 5, 2011 Share #4 Posted August 5, 2011 I purchased led strips from Harbor Freight. It took four strips. Two on each side. cost about $7 each. I attached them with two sided tape and connectors from the local computer store. Mike Link to comment Share on other sites More sharing options...
Hummingbird Posted August 5, 2011 Share #5 Posted August 5, 2011 I put some under the tank, some under the seat and on the front lower fairing. Attached are 3 pics showing the colors but if you go to the site you can see all the colors this particular kit will do - and it's remote. you can strobe, flicker - all sorts of ways to light up. Plus it's plug and play. I also went to the extreme and put them on a relay - plus a lifetime guarantee Link to comment Share on other sites More sharing options...
