painterman67 Posted July 29, 2011 Share #1 Posted July 29, 2011 well it apears that the final drive on my 91 vr is giving up its innards. Its making the dreaded howl when you let off the throttle. Kinda sounds like a dump trunk thats using the engine as a break. Does anybody have one that will fit they are willing to let go of. I have already talked to muffinman as to weather or not its the final or something else. I had the rear end and axle and drive shaft greased at the dealor and it didnt help. They even agreed that it was the final but no way Im paying $1500 for them to rebuild it.. anyways any help will be apreciated. Even if its ideas to check instead of replacement. Im even thinking of pulling the rear tire myself to regrease it . I have no idea what Im doing but Im sure with the help of this site and great members I can figure it out. Thanks in advance, David Link to comment Share on other sites More sharing options...
jasonm. Posted July 29, 2011 Share #2 Posted July 29, 2011 EBAY...sometimes you find LOW mileage units from 86-93...I did for less than $100. I don't like using the Vmax or FJR rear drives. Just sucks gas. At least one person installed a RS Venture rear...But he said there is a slight offset...to the left I think. I suggest being patient on Ebay. I think you may be able to buy for about $1100 - $1200 new if available. Also what's the mileage on the original ? Link to comment Share on other sites More sharing options...
painterman67 Posted July 29, 2011 Author Share #3 Posted July 29, 2011 the original has 80,000 on it. And yeah I been watching ebay but thought it would be nice to help a member out if they needed or wanted to sell one. David Link to comment Share on other sites More sharing options...
Jrichard Posted July 29, 2011 Share #4 Posted July 29, 2011 David--------pinwall has 3: 1200 pumpkins------fer 69.95+s&h -don't know if the 1200 rear will fit your 91 or not:group cheers:-----consult w/the higher VR powers!!!!!-------------- Link to comment Share on other sites More sharing options...
MiCarl Posted July 30, 2011 Share #5 Posted July 30, 2011 I have a 2nd gen final in my 89. Yes, it does shift the tire slightly to the left. I've yet to take it back out and figure out why. You do have to close off the hole for the speedometer pick up (or leave a pick up in there). In my case the pinion shaft had broken. There is no rebuilding that, Yamaha doesn't sell the parts separately. You have to replace the whole drive. The price the dealer gave you sounds like a full replacement unit (Cycle Parts Nation currently lists it at $1041.04). Labor to install one is not a lot. You should make sure it's the final drive before replacing it - I suspect a problem at the middle gear makes a similar sound. If the pinion shaft is broken it's easy to diagnose: Just pull the final drive and see if the drive shaft coupler will pull out of the final. If it does it's broken. Link to comment Share on other sites More sharing options...
Grisolm1 Posted July 30, 2011 Share #6 Posted July 30, 2011 I had same noise. Broken pinion shaft. Don't shy away from a vmax rear. I and several others saw no increase in fuel consumption and it makes the bike much snapping. Also plenty of vmax rears out there. 85 up 1200 vmax will all work. Link to comment Share on other sites More sharing options...
Grisolm1 Posted July 30, 2011 Share #7 Posted July 30, 2011 Just did a search and found a few fjr pumpkins for less than $100. Vmaxs were 2x that. Search for." EBay fjr1300 final drive" I bought one for my RSV. Now gotta find someone with a milling machine. Link to comment Share on other sites More sharing options...
skydoc_17 Posted July 30, 2011 Share #8 Posted July 30, 2011 Hey David, I have an MKII Final Drive from a 29,xxx mile bike. Direct bolt on unit, position of rear wheel will not change. If you are interested, PM me. Earl Link to comment Share on other sites More sharing options...
painterman67 Posted July 30, 2011 Author Share #9 Posted July 30, 2011 Hey David, I have an MKII Final Drive from a 29,xxx mile bike. Direct bolt on unit, position of rear wheel will not change. If you are interested, PM me. Earl[/QUOPm sent ...hope I can get this started soon as it may take me a year or 2 to figure out how to replace once I buy one. David Link to comment Share on other sites More sharing options...
jasonm. Posted July 30, 2011 Share #10 Posted July 30, 2011 well it apears that the final drive on my 91 vr is giving up its innards. Its making the dreaded howl when you let off the throttle. Kinda sounds like a dump trunk thats using the engine as a break. Does anybody have one that will fit they are willing to let go of. I have already talked to muffinman as to weather or not its the final or something else. I had the rear end and axle and drive shaft greased at the dealor and it didnt help. They even agreed that it was the final but no way Im paying $1500 for them to rebuild it.. anyways any help will be apreciated. Even if its ideas to check instead of replacement. Im even thinking of pulling the rear tire myself to regrease it . I have no idea what Im doing but Im sure with the help of this site and great members I can figure it out. Thanks in advance, David I have had my '87 since '89....mine has always made a mild whine when letting off the gas. I suspect what you are hearing is NOT mild. Link to comment Share on other sites More sharing options...
jasonm. Posted July 30, 2011 Share #11 Posted July 30, 2011 I had same noise. Broken pinion shaft. Don't shy away from a vmax rear. I and several others saw no increase in fuel consumption and it makes the bike much snapping. Also plenty of vmax rears out there. 85 up 1200 vmax will all work. If you drive hi-way at the speeds I do...your mileage would go down. Also in very hot weather the bike will run hotter....especially on the interstate. I don't like comprimise... Link to comment Share on other sites More sharing options...
jasonm. Posted July 30, 2011 Share #12 Posted July 30, 2011 Hey David, I have an MKII Final Drive from a 29,xxx mile bike. Direct bolt on unit, position of rear wheel will not change. If you are interested, PM me. Earl[/QUOPm sent ...hope I can get this started soon as it may take me a year or 2 to figure out how to replace once I buy one. David MKII ...you mean 86-93...yes...? Link to comment Share on other sites More sharing options...
painterman67 Posted July 31, 2011 Author Share #13 Posted July 31, 2011 I have had my '87 since '89....mine has always made a mild whine when letting off the gas. I suspect what you are hearing is NOT mild. nope what Im hearing is not mild. It was mild when I bought the bike 20,000 miles ago. Now its getting loud er as time goes on. David Link to comment Share on other sites More sharing options...
painterman67 Posted July 31, 2011 Author Share #14 Posted July 31, 2011 MKII ...you mean 86-93...yes...? yes mkII means 86-93 David Link to comment Share on other sites More sharing options...
painterman67 Posted July 31, 2011 Author Share #15 Posted July 31, 2011 I had same noise. Broken pinion shaft. Don't shy away from a vmax rear. I and several others saw no increase in fuel consumption and it makes the bike much snapping. Also plenty of vmax rears out there. 85 up 1200 vmax will all work. Not shying away from the vmax for fuel reasons. The gear ratio woiuld raise my rpms to an uexceptable range for me. Not saying its bad but a lot of times with the group I ride with its 75-80 mph. At that speed Im already in the 4500 rpm range and from what I understand the vmax rear will raise the rpms aproximately 500 -600. So I would be at 5000-5100 at those speeds and I know the motor will handle it but jsut not willing to push a 20 yr motor that hard for hrs at a time> David Link to comment Share on other sites More sharing options...
Grisolm1 Posted July 31, 2011 Share #16 Posted July 31, 2011 Understand your concern. Most of my riding is not superslab so 40-70 mph cruising is what I like vmax gears for. Sounds like you will be able to find stock gears ok. Link to comment Share on other sites More sharing options...
