Starider0106 Posted May 27, 2011 Share #26 Posted May 27, 2011 Good luck with the surgery, I am still waiting to get an MRI to determine course of action with my L5 S1 issues. Positive thoughts and prayers to you Link to comment Share on other sites More sharing options...
Scooter Bob Posted May 27, 2011 Share #27 Posted May 27, 2011 From all the replies to this thread, I'm starting to think there is something wrong with the VENTURE seats. Oh wait a minute, I was riding a shovelhead when my problems started and I had the first L5-S1 discectomy in 95. Link to comment Share on other sites More sharing options...
painterman67 Posted May 27, 2011 Share #28 Posted May 27, 2011 prayers sent my friend.Either way the man upstairs has his ears full. Godspped and heal well David Link to comment Share on other sites More sharing options...
Scooter Bob Posted May 28, 2011 Share #29 Posted May 28, 2011 (edited) Hey Dingy, and others, Have you talked to your DR or Chiropractor about using an inversion table?? My regular guy was a little leary about using one before the decompression therapy I started yesterday, but the new Chiro that has the decompression machine(the rack) said he uses one himself, and that it would be alright for a couple minutes at a time. I bought one yesterday at Dunham Sports($150) and slowly put it together. First tip over to the lowest setting(about 20 degrees) pulled everything 10 times harder than the decompression machine, and seemed like way too much to start with. I stuck some blocks of wood in it to lessen the tilt to about 10 degrees, and used it several times yesterday afternoon and evening for a minute or two at a time. It's definately helping. Much more flexibility without pain last night, probably 80% of normal. Although I seemed to have pulled a couple muscles in my legs I didn't know I had. You don't need to be upside-down like Roger Teeter in the commercials. Just a little bit over level, and you can push the handles to get a little more stretch if needed. Just a thought, and I'll keep you posted. Good Luck, Scooter Bob Edited May 28, 2011 by Scooter Bob Link to comment Share on other sites More sharing options...
dingy Posted May 28, 2011 Author Share #30 Posted May 28, 2011 Hey Dingy, and others, Have you talked to your DR or Chiropractor about using an inversion table?? My regular guy was a little leary about using one before the decompression therapy I started yesterday, but the new Chiro that has the decompression machine(the rack) said he uses one himself, and that it would be alright for a couple minutes at a time. I bought one yesterday at Dunham Sports($150) and slowly put it together. First tip over to the lowest setting(about 20 degrees) pulled everything 10 times harder than the decompression machine, and seemed like way too much to start with. I stuck some blocks of wood in it to lessen the tilt to about 10 degrees, and used it several times yesterday afternoon and evening for a minute or two at a time. It's definately helping. Much more flexibility without pain last night, probably 80% of normal. Although I seemed to have pulled a couple muscles in my legs I didn't know I had. You don't need to be upside-down like Roger Teeter in the commercials. Just a little bit over level, and you can push the handles to get a little more stretch if needed. Just a thought, and I'll keep you posted. Good Luck, Scooter Bob I did ask Dr about this. In my case the bad disk is extruded so far into spinal canal that only thing that will repair it is get the extruded part out. This might be helpful on a bulging disc, but I am past that point. Gary Link to comment Share on other sites More sharing options...
