friesman Posted May 15, 2011 Posted May 15, 2011 (edited) My first ride of the year the class system was working fine, and then i had the error show up so I did the solder contacts on the class display head. Reassembled it, I could hear a click from the back when I used the class panel but compressor wouldnt run,and then got the e2 error. i really didnt know what it was but had a look at the compressor unit and found it had puked out oil everywhere over license plate etc. So i ordered a replacement compressor unit from ebay and installed yesterday, same issue, the class panel comes up normally but when i select front or back and adjust pressure i hear a solenoid click once but no compressor running and then after a minute the e2 error comes on. What am I missing, is there another componenet that is faulty? or did I get another compressor that doesnt work? Thanks in advance for any help, brian Edited May 15, 2011 by friesman
bongobobny Posted May 15, 2011 Posted May 15, 2011 Uhhhh, oil in the air system?? Sounds liks a bad seal on one of the forks or rear shock...
Marcarl Posted May 15, 2011 Posted May 15, 2011 Too much oil in your front shocks??,,,,, depends on where the oil is,,,, you might determine that by removing the lines from the compressor to see if there is one without oil.
