Lassesand Posted April 20, 2011 Posted April 20, 2011 My plastic gear for the odo is worn out so it wont turn the steel shaft and the odo doesen't work What to do? Find a good used speedo at ebay or can it be fixed? I was thinking something like using a glue gun and adding material to the plastic gear and try to reshape it...
mbrood Posted April 20, 2011 Posted April 20, 2011 I would think with the MANY revolution it sees, there's really only the options of replacement gears or replace the unit. Quick fixes here just don't sound right.
Venturous Randy Posted April 20, 2011 Posted April 20, 2011 I would think with the MANY revolution it sees, there's really only the options of replacement gears or replace the unit. Quick fixes here just don't sound right. I agree. These units show up on ebay pretty cheap sometimes. RandyA
Pegasus1300 Posted April 21, 2011 Posted April 21, 2011 I have tried to fix 2 of these units and been unsuccessful.That doesn't mean it can't be done but I couldn't figure one out.The problem is that the gears are held in place by a punch mark in the mounting holder and removing the mark also removes enough material that I couldn't put in a new punch.I ended up replacing the unit off ebay.I now grease that gear on a regularly with LaBelles 109 locomotive grease an item found in hobby shops that sell model railroading supplies.It is plastic compatable and will not cause the gear to become brittle.
