cimack77 Posted February 22, 2011 Share #1 Posted February 22, 2011 Has anyone just changed the fork oil on a 1st Gen without removing the forks.? I know there is a drain plug at the bottom of the forks. Link to comment Share on other sites More sharing options...
mm482 Posted February 23, 2011 Share #2 Posted February 23, 2011 You do not need to remove the forks to change fork oil. I hope this link will help you. http://www.venturerider.org/forum/showthread.php?t=505 Earl Link to comment Share on other sites More sharing options...
tazmocycle Posted February 23, 2011 Share #3 Posted February 23, 2011 you may want to use 10w oil back if you doing it for the first time.mthe heavier oil will make the frontend not dive as bad as 5w oem oil. good to keep a little air on shocks to less the diving when braking hard. Link to comment Share on other sites More sharing options...
Zane Posted February 23, 2011 Share #4 Posted February 23, 2011 While you have 'em opened up, put in a set of Progressives! Way better! Yessir! Link to comment Share on other sites More sharing options...
cimack77 Posted February 23, 2011 Author Share #5 Posted February 23, 2011 Thanks everyone for their help. cimack77 Link to comment Share on other sites More sharing options...
