warriorhoneybee Posted November 7, 2010 Posted November 7, 2010 gee, look sleeperhawk,i think i got my money out of these. http://www.venturerider.org/forum/picture.php?albumid=800&pictureid=5040
Eck Posted November 7, 2010 Posted November 7, 2010 gee, look sleeperhawk,i think i got my money out of these. http://www.venturerider.org/forum/picture.php?albumid=800&pictureid=5040 You might want to check your rear rotor... it may have to get more money out of YOU...if it is damaged...
warriorhoneybee Posted November 7, 2010 Author Posted November 7, 2010 i think your right eck but gonna try to see how it dose. george looked at it and thought it would be alright but i dont know after taking the pads off and seeing how bad they were.
Eck Posted November 7, 2010 Posted November 7, 2010 george looked at it and thought it would be alright but i dont know after taking the pads off and seeing how bad they were. That George guy is a pretty sharp fella. (Good plug for ya huh George..) If there are a few ground line marks in the rotor you should be OK..depending on how deep they are. By the looks of your pads they shouldn't be that deep. Your new pads will end up having those same line marks in them within the first two hundred miles.Just swap out the outer pad with the inner pad in about 7k to 12k miles. All depends on how you go about stopping your bike. I got to where I VERY seldom even used the rear brake. I only used the front when I needed to and always slowed down way before the intersections..
warriorhoneybee Posted November 7, 2010 Author Posted November 7, 2010 thanks for the info again eck,i thought about changing the pads every 10,000 miles from inside and outside to try to keep them even. i dont think theres a directaul dirrerance in the pads so i should be alright.
1rooster Posted November 7, 2010 Posted November 7, 2010 gee, look sleeperhawk,i think i got my money out of these. http://www.venturerider.org/forum/picture.php?albumid=800&pictureid=5040 You should have switched the inside with the outside a few months ago and you might have gotten a couple more thousand out of them
warriorhoneybee Posted November 7, 2010 Author Posted November 7, 2010 yes i should have rooster but next time i'll know.
Yammer Dan Posted November 7, 2010 Posted November 7, 2010 You should quit riding the brake all the time. Might be able to keep up then plus saving a lot of brake pads.....
naturbar Posted November 7, 2010 Posted November 7, 2010 gee, look sleeperhawk,i think i got my money out of these. http://www.venturerider.org/forum/picture.php?albumid=800&pictureid=5040 how many miles did you get from those pads??
Sleeperhawk Posted November 7, 2010 Posted November 7, 2010 gee, look sleeperhawk,i think i got my money out of these. http://www.venturerider.org/forum/picture.php?albumid=800&pictureid=5040 Definitly got your money's worth and then a little bit more.
Sleeperhawk Posted November 7, 2010 Posted November 7, 2010 You should quit riding the brake all the time. Might be able to keep up then plus saving a lot of brake pads..... On the 2nd gens, I hardly use the rear brake and they still wear out quick. I always check them when I have the rear bags off. Have not replaced the front ones yet, even with 47000 miles on them.
Yammer Dan Posted November 7, 2010 Posted November 7, 2010 I use the front a lot more. They looked about like that on "Ugly" maybe a little worse when I changed them at the 1st Ashville meet. Still haven't changed the back ones. About the only time I use the rear is coming to a complete stop or when cruising at "Warp" speeds. I feel a lot safer bringing it back down with the rear??
