Meaton03 Posted October 6, 2010 Posted October 6, 2010 Hi Guys and Gals... I have a holes in the chamber thing and I cannot get it a patch to hold for anything. I have tried muffler patch and the clay stuff that turns into metal, even a screw and the clay/metal stuff and that still blew out. It is annoying but I just want to make sure it won't affect the engine in any negative way. I prefer a nice quick ride but I can put up with the pseudo Harley sound. I do not know what the chamber is called but it is connected to the pipes from the engine then to the mufflers. Help I am going nuts with this. Thanks, Mark '86 VR
Trader Posted October 6, 2010 Posted October 6, 2010 E-bay...they ("collectors") come up from time to time. Or take it to a muffler shop and see if they can weld it.
6m459 Posted October 7, 2010 Posted October 7, 2010 I recently tried some of this stuff on a car exhaust. It was a big hole where a weld had rusted out, oval shaped 1/2" x 1" in size approximately and the repair worked out a great success. http://www.permatex.com/images/DisplayImage.asp?210|/images/ProductPhotos/80331.jpg Permatex® Muffler & Tailpipe Bandage Epoxy-impregnated fiberglass bandage chemi- cally welds mufflers and tailpipes. Permanently repairs holes and leaks in exhaust systems saving costly part replacement. Seals out poisonous fumes to temperatures of 800°F (426°C). Suggested Applications: Mufflers and tailpipes on automobiles, trucks, tractors and farm equipment Hope this helps.
MasterGuns Posted October 7, 2010 Posted October 7, 2010 I'd remove the entire collector and have it welded; the only lasting way to repair the thing.
Yammer Dan Posted October 7, 2010 Posted October 7, 2010 (edited) At the 1st Vogel I tried and tried to patch the one on the "Blue Beast" Sure got everybody's attention when I fired her up!!! One on E-Bay now but they don't come cheap. Edited October 7, 2010 by Yammer Dan
steve crossley Posted October 7, 2010 Posted October 7, 2010 some where on this site there is an no . and address for a collector from mark pipe . after buying one from him i made a point to get it entered here so check around. it is not cheap but it is real good sounds real fine . check it out:smile5:
Rocket Posted October 7, 2010 Posted October 7, 2010 some where on this site there is an no . and address for a collector from mark pipe . after buying one from him i made a point to get it entered here so check around. it is not cheap but it is real good sounds real fine . check it out:smile5: Last price I saw on a Mark's Pipes collector (posted on this site), it was about $200. more, than a new OEM collector from Yamaha. :mo money:
Meaton03 Posted October 9, 2010 Author Posted October 9, 2010 Thanks for the tips everyone. I figured it would probably have to be welded. I will try the tape so I can ride it this weekend (80's here in Chicago) then take it off to get it welded.
GeorgeS Posted October 9, 2010 Posted October 9, 2010 If you take it to a welder, remember its made of Stainless Steel. So make sure the welder knows that.
steve crossley Posted October 9, 2010 Posted October 9, 2010 Last price I saw on a Mark's Pipes collector (posted on this site), it was about $200. more, than a new OEM collector from Yamaha. :mo money: i just priced a new oem collector on parts shark there price was 463.29 mark pipe colector in stainless steel cost me 330.00 . the way it runs and sounds is much better. make shure you use new gaskets all around .i think you would be very happy with it.
Yammer Dan Posted October 10, 2010 Posted October 10, 2010 Thanks for the tips everyone. I figured it would probably have to be welded. I will try the tape so I can ride it this weekend (80's here in Chicago) then take it off to get it welded. Collector will remove it for you!!
steve crossley Posted October 10, 2010 Posted October 10, 2010 to whom it may matter, Marks performance products 18011 westlawn st. hesperia ca 29345 phone no - 760-948-1346 email - markpipe@neto.net stainless steel --$330.00 also makes ceramic and a steel one the last i heard that is less cash
