star4772 Posted September 30, 2010 Posted September 30, 2010 to mount the pillow top seats on the RSTD I have seen them on the RSTD but need to know how they would mount and if anyone has any pic's of what is needed and how they go on. Thanks star4772 :confused24:
RoyalStarRider Posted September 30, 2010 Posted September 30, 2010 I have the drivers pillow top on mine (well I did until a couple of days ago) and the previous owner simply used 2 small "L" brackets to attach it to the frame (in the stock position)... cant help you with the passengers seat.
star4772 Posted September 30, 2010 Author Posted September 30, 2010 I have the drivers pillow top on mine (well I did until a couple of days ago) and the previous owner simply used 2 small "L" brackets to attach it to the frame (in the stock position)... cant help you with the passengers seat. Do you still have the driver pillow top and do you want to sell it? Joe
Condor Posted September 30, 2010 Posted September 30, 2010 Do you still have the driver pillow top and do you want to sell it? Joe Joe, I think Pinwall has a Pillow Top driver on Ebay right now.....
mountainhorsega Posted September 30, 2010 Posted September 30, 2010 For the front, there are a couple of small "L" brackets. look in the tech section - there is a drawing for them or jemorrisonjr has the drawing. Easy to install. (I think we got the last ones he had - pm jemorrisonjr to see if he has any more.) for the rear, you need the mounting bracket (Pinwall removes it and sells it separately.) I might be able to find the pick of it from ebay but, I think they list it as a venture seat bracket. you wont have a back bolt like the TD does now. replace the front td bracket with the Venture one(it's a direct swap with the three mounting bolts holding it to the fender) and put the two bolts in. We have done over a thousand miles since we put them on and they have been great. Went on the trail of tears - close to 400 miles in one day - went to the dragon and back - 400 miles in one day, went to Dahlonega and back about 300 miles in one day.
star4772 Posted October 1, 2010 Author Posted October 1, 2010 For the front, there are a couple of small "L" brackets. look in the tech section - there is a drawing for them or jemorrisonjr has the drawing. Easy to install. (I think we got the last ones he had - pm jemorrisonjr to see if he has any more.) for the rear, you need the mounting bracket (Pinwall removes it and sells it separately.) I might be able to find the pick of it from ebay but, I think they list it as a venture seat bracket. you wont have a back bolt like the TD does now. replace the front td bracket with the Venture one(it's a direct swap with the three mounting bolts holding it to the fender) and put the two bolts in. We have done over a thousand miles since we put them on and they have been great. Went on the trail of tears - close to 400 miles in one day - went to the dragon and back - 400 miles in one day, went to Dahlonega and back about 300 miles in one day. Thanks I think I have a line on everything I need. Joe
