majkongb52 Posted July 26, 2010 Posted July 26, 2010 I installed a glass mat battery that is sealed and now have no place for the battery probe and of course the warning light stays on. Is there a remedy for this. Thanks
Props Posted July 26, 2010 Posted July 26, 2010 check it out.... http://www.venturerider.org/forum/showthread.php?t=489
Rody 1949 Posted July 26, 2010 Posted July 26, 2010 Great solution. My problem is I don't have an accessory fuse, I have three spare fuses on the back of the cover. (my bike is a Venture 86) Where would my lead be connected to? Thank you so much.
MiCarl Posted July 27, 2010 Posted July 27, 2010 Unless the fuse box has been changed you do have an accessory fuse. The two screws just forward of the stock box are for accessory connection (one is hot, the other is ground). Realistically though you can hook it to any switched hot.
Rody 1949 Posted July 28, 2010 Posted July 28, 2010 Unless the fuse box has been changed you do have an accessory fuse. The two screws just forward of the stock box are for accessory connection (one is hot, the other is ground). Realistically though you can hook it to any switched hot. Got it! Thank you so much.
