pick Posted June 11, 2010 Share #1 Posted June 11, 2010 Changed to the Iso grips, like the larger diameter. I read some of the previous threads aboue glue. I tried the dish soap, didn't hold. Tried black gasket sealer, that didn't hold. I'm reluctant to use the Iso grip glue and they say its PERMANANT. I want to take them off here shortly and modify them to put the factory weights back on. Any suggestions as to what glue will hold them from turning and still be able to remove them from the bars without ruining them? Link to comment Share on other sites More sharing options...
t_hole Posted June 11, 2010 Share #2 Posted June 11, 2010 I've had success using golf grip tape. Wrap it around the bar and wet it with mineral spirits or lighter fluid. Grips will slide on nicely and will allow you plenty of time to adjust so they're lined up just the way you want them. Make sure to cover the tank as the lighter fluid is pretty harsh on the paint. Link to comment Share on other sites More sharing options...
slick97spirit Posted June 11, 2010 Share #3 Posted June 11, 2010 I've used hair spray in the past and it worked well. Link to comment Share on other sites More sharing options...
rod Posted June 11, 2010 Share #4 Posted June 11, 2010 plus one on the hair spray. Rod Link to comment Share on other sites More sharing options...
TomMar Posted June 11, 2010 Share #5 Posted June 11, 2010 My vote is also for the hair spray. It holds well (the grips that is) and is not difficult to remove the grips later on. Link to comment Share on other sites More sharing options...
Squidley Posted June 11, 2010 Share #6 Posted June 11, 2010 I know you already have them, but I would watch them close. I had a set break in half between the rubber squares, I wouldn't buy another set myself. I have had luck with a bit of soapy water. Link to comment Share on other sites More sharing options...
pick Posted June 11, 2010 Author Share #7 Posted June 11, 2010 Well, test three, just cleaned up the gasket sealer and gave em a good dose of wifeys mega hold hair spray, gona let them set overnight and see what happpens. Gotta trip planned to NC Wed. and would like them to be set for the trip. Link to comment Share on other sites More sharing options...
royalstarjac Posted June 11, 2010 Share #8 Posted June 11, 2010 Well, test three, just cleaned up the gasket sealer and gave em a good dose of wifeys mega hold hair spray, gona let them set overnight and see what happpens. Gotta trip planned to NC Wed. and would like them to be set for the trip. Really no need to let them sit. 5 minutes should do. Link to comment Share on other sites More sharing options...
