a1bummer Posted May 16, 2010 Posted May 16, 2010 I'm trying to stop a slow oil drip that appears to be coming from the left side of the crank/trans case. So I'm going to replace the clutch shaft oils seal (93109-08061-00), and the shift shaft oil seal (93102-12106-00, (SD 12-22-5 HS)). I was also gonna shim any loose or worn areas while I was in there. Is there anything else I should be looking at down there that may be causing the drip? I don't want to be having to crack open things any more than I have to. Thanks, Bill
bkuhr Posted May 17, 2010 Posted May 17, 2010 Not sure what kind of bike you have XVZ12/13 has crush washer bottom bolt left transmission(middle gear) cover. May be all you need.
a1bummer Posted May 17, 2010 Author Posted May 17, 2010 Are your referring to this little guy? #23 P/N 90430-06014-00 If so I'll check it out before I do any of the seals. Thanks, Bill
Condor Posted May 17, 2010 Posted May 17, 2010 While you're in there replace the O-ring on the neutral sensor. That's probably were you're leaking anyway.... Dingy has pics of the '84 style neutral switch.
dingy Posted May 17, 2010 Posted May 17, 2010 While you're in there replace the O-ring on the neutral sensor. That's probably were you're leaking anyway.... Dingy has pics of the '84 style neutral switch. There are some pictures of neutral switch in the PDF file that is attached to the post linked below. Shows its location and how to get to it. http://www.venturerider.org/forum/showthread.php?t=40639 Gary
bkuhr Posted May 17, 2010 Posted May 17, 2010 Are your referring to this little guy? #23 P/N 90430-06014-00 If so I'll check it out before I do any of the seals. Thanks, Bill YEP
