Chinto Posted March 31, 2010 Share #1 Posted March 31, 2010 I was looking through the AMSOIL brochure and found Amsoil Spray Grease. See the link for specific details of this grease. http://www.amsoil.com/storefront/glcspray.aspx Anyway a though occured to me and I am wondering what you think about this idea. Would this or similair grease, but a spray type grease being sprayed into the access port on top of the engine side drive shaft knuckle/driveshaft gear be sufficient lubrication? Even if you would do it a couple times/year. I have never looked into this port yet but all of the posts say you can feel the knuckle that accepts the shaft end so spraying this grease, maybe with tube on the end of the spray can to direct the grease better should get it on the gearing. Granted this is no substitute for a complete lube job tear down but maybe in between lubing when the tire doesn't need to be taken off, could it be effective? Or is this grease simply not suitable for this type of application? What do you all think??? Link to comment Share on other sites More sharing options...
Freebird Posted March 31, 2010 Share #2 Posted March 31, 2010 First of all, I would doubt that it is a heavy enough grease but the main thing is that I think all the grease is going to end up on the outside casing of the U-Joint and not between the shaft and inner splines of the joint where it needs to be. Link to comment Share on other sites More sharing options...
gator06 Posted April 1, 2010 Share #3 Posted April 1, 2010 I just completed two grease job's on the drive line. Spray will not get to where it's needed. Next time you lube the drive shaft and final drive fingers, use a Water Proof / Marine - Molly grease. I use Shaffer brand grease, stays where you put it. Link to comment Share on other sites More sharing options...
Squidley Posted April 1, 2010 Share #4 Posted April 1, 2010 I'm with Freebird, anything that is light enough to be sprayed out of a can isn't heavy enough to do the job. Stick with a good grease and you wont have issues Link to comment Share on other sites More sharing options...
Riderduke Posted April 1, 2010 Share #5 Posted April 1, 2010 Yup, Sleeperhawk and I just used Honda Moly 60 on mine! I also agree that a spray grease would be too thin! Just my Link to comment Share on other sites More sharing options...
KiteSquid Posted April 1, 2010 Share #6 Posted April 1, 2010 I would use Honda Moly60 sparingly on the splines of the drive shaft (both ends) , the spline and the drive fingers of the clutch hub for long parts life...... Link to comment Share on other sites More sharing options...
Chinto Posted April 2, 2010 Author Share #7 Posted April 2, 2010 Thanks for your input. I figured those who have been in there and seen the setup would know best. Thanks Link to comment Share on other sites More sharing options...
