dingy Posted September 6, 2009 Share #1 Posted September 6, 2009 Would someone scan the wiring schematic that is in the back of the owners manual and post it or email to me please. I need a 83-85 Venture Royale schematic. I have a stock 83 Venture and am going to put cruise in from a 84 venture. I have the wiring harness that I may use to replace mine. I want to look at the schematic and see if there are any differences in the connectors besides the dash hookups. I think the brake/clutch switches are different also. Thanks dingy101@live.com Link to comment Share on other sites More sharing options...
SaltyDog Posted September 6, 2009 Share #2 Posted September 6, 2009 Have you tried the first gen tech section and downloaded the manuals there? [ame=http://www.venturerider.org/forum/showthread.php?t=3384]First Gen Service Manuals - VentureRider.Org[/ame]. Lots of good info to get you moving in the right direction. Link to comment Share on other sites More sharing options...
dingy Posted September 6, 2009 Author Share #3 Posted September 6, 2009 The schematic that is in the service manual in taht section is the one for the stock venture. I am looking for one from a Royale. The cruise is covered in the supplementary manual for the royale but does not include a detailed schematic, it shows a block diagram only. I am looking for wire colors and connector shapes that are shown on the detailed schematic. Link to comment Share on other sites More sharing options...
Ozlander Posted September 6, 2009 Share #4 Posted September 6, 2009 I looked at my 83-84 Service Manual (which I use for my '89) and the wiring diagram in the back is the same as my '83 Manual. The block diagram is all you get. Maybe a later manual, which I have never looked at, will have the cruise control worong in it. I can tell you the clutch switch and front brake switch is different, and probably the rear brake, in they have both N.O. and N.C. contacts. Link to comment Share on other sites More sharing options...
dingy Posted September 6, 2009 Author Share #5 Posted September 6, 2009 Thank You, I will try to add it to my existing one then, I have traced it out in AutoCad so I can print it out larger. Link to comment Share on other sites More sharing options...
SaltyDog Posted September 6, 2009 Share #6 Posted September 6, 2009 I've attached a few circuit and components diagrams from the XVZ13 manual showing the cruise control system. Check out the wire colors and see if they are the same. The 1200 and 1300 share many components so these should be close. Hope this is on some use.. Link to comment Share on other sites More sharing options...
dingy Posted September 6, 2009 Author Share #7 Posted September 6, 2009 Thank You, This will be very helpful. Gary Link to comment Share on other sites More sharing options...
