SoJourner Posted September 20, 2007 Posted September 20, 2007 My Radio quit working this morning. Can anyone tell me what things I should check before taking it to the dealer? Thanks, Mark
gibvel Posted September 20, 2007 Posted September 20, 2007 What did it do? I suspect that it's the connections in the faring. Lots of people have had the problem with the controller. Either it comes on and the buttons won't work or it will not come on at all. Either case, most of the time, it can be linked to the connectors for the radio and or handlebar controller unit inside the faring. The fix is to split the faring and take all the audio connectors apart, clean them, put dielectric grease on them and then put them back together. There are also some connectors to the rear audio/intercom/CB under the passengers seat that could use the same treatment. Hope this helps you out. I'll look for Freebird's "how to split your faring" tech article and post a link to it. Here it is: http://www.venturerider.org/forum/showthread.php?t=494&highlight=splitting+faring If you have an MP3 player or a GPS unit this might be a good opportunity to hook up a "Y" splitter on the auxiliary input plug so you can run a cable to the handle bars for inputing the output of either of those devices to the auxiliary of the stereo and leave the one in the cassette compartment free for a second input.
Eck Posted September 20, 2007 Posted September 20, 2007 My Radio quit working this morning. Can anyone tell me what things I should check before taking it to the dealer? Thanks, Mark Mark, I can help you fix it tonight, or tomorrow for you. Most likely, you need Dialectric grease on the connectors (got to split the fairing) Not a hard ask at all to pull the connector apart and add the grease.. I dont remember, but do you have a back rest on yours? If so, the problem could also be a pinched wire between back rest bracket and rear fender (dont ask me how I know this)...
SoJourner Posted September 20, 2007 Author Posted September 20, 2007 Gibvel, It stopped letting me switch modes then turned off. Now it won't come on. Eck, I will not be able to do it tonight and will be gone all weekend. How about one evening next week? Thanks, Mark
Eck Posted September 20, 2007 Posted September 20, 2007 Eck, How about one evening next week? Sounds like a plan to me!!! Next Saturday, I am leaving real reearly for Panam City. Any evening next week is fine with me bud. Heck we cant break it...it's already broke..
gibvel Posted September 20, 2007 Posted September 20, 2007 Sounds like the problem and sounds like you and Eck have got things under control!
dray Posted September 20, 2007 Posted September 20, 2007 i was at the dealer yesterday talking to the wrench and a guy stoped to get his VR they had just replaced the controler on the bars it went bad it was replaced under warrenty that small controler is not cheap if you have to pay for it 580. is what Larry told me the price was for it
SoJourner Posted September 20, 2007 Author Posted September 20, 2007 Thanks all. I will get with Eck next week and check to be sure it is not just a connection problem, before I take to the dealer. They already replaced the Control head once. Mark
Eck Posted September 20, 2007 Posted September 20, 2007 Possible problem....... Loose nut between control knob and seat.......... :rotf::rotf::rotf::rasberry::rasberry::rasberry::rasberry::rasberry::rasberry::cool10::cool10::whistling::buttkick:
SoJourner Posted September 20, 2007 Author Posted September 20, 2007 Eck, That is not a possibility.....it is a fact. Mark
BuddyRich Posted September 20, 2007 Posted September 20, 2007 There's alot of them things around here for some reason....
