FROG MAN Posted July 15, 2009 Share #1 Posted July 15, 2009 I need a few things for my new laptop running Vista home edition 32 bit. 1. A good USB serial cable adapter with drivers. 2. A terminal emulator program like hyper terminal or something else. 3. Will dos box run older programs? I'm trying to get the new laptop doing all I can. Tired of carrying two laptops just to maintain communications gear in the field. Now I got three computers on the truck. Link to comment Share on other sites More sharing options...
juggler Posted July 15, 2009 Share #2 Posted July 15, 2009 I need a few things for my new laptop running Vista home edition 32 bit. 1. A good USB serial cable adapter with drivers. 2. A terminal emulator program like hyper terminal or something else. 3. Will dos box run older programs? I'm trying to get the new laptop doing all I can. Tired of carrying two laptops just to maintain communications gear in the field. Now I got three computers on the truck. Any computer store should have the cable I use PuTTY for my terminal program when I'm forced to use Windows http://www.chiark.greenend.org.uk/~sgtatham/putty/ I never heard of Dos Box. I just downloaded the Mac OS X version. Ask them about support. Link to comment Share on other sites More sharing options...
juggler Posted July 15, 2009 Share #3 Posted July 15, 2009 I just setup Dos Box on my Mac. Wow, what a flash back to the 80's and early 90's. It's been that long since I worked in DOS on a regular basis. These days when I'm in a command line OS it's Linux or other *nix variant. It reports as Dos 5.0 so it should run older software as long as the software isn't to complex. They report that they are still working on getting it able to run all Dos software. The real trick may be getting Dos Box to recognize your USB port. This is difficult for many emulators. Link to comment Share on other sites More sharing options...
FROG MAN Posted July 15, 2009 Author Share #4 Posted July 15, 2009 I been reading that several usb serial cables are not vista supported. I was hoping somebody has tested one with vista. Most of the software I run is windows only programs but we still service equipment using dos based software.It seems the two way radio vendors are all wrapped up with Microsoft. Link to comment Share on other sites More sharing options...
BuddyRich Posted July 15, 2009 Share #5 Posted July 15, 2009 http://www.usconverters.com/index.php?main_page=product_info&cPath=67&products_id=195&gclid=CPrdusjE15sCFQJ2xgodk1MXnA Link to comment Share on other sites More sharing options...
