Cougar Posted May 26, 2009 Posted May 26, 2009 I know , I know ya think I am crazy . Anyways, I got this project finished today. I now can run both Odyssey Battery's at the same time or run one at a time with my Big Perko Switch! The Odyssey in the trunk is the 680 a little larger, I also am going to put my cell charger and some other stuff to power off of the trunk battery. I can charge both at the same time or one at a time. OR run BOTH at 12 volts at the same time now. I still have to put a rubber cover over the positive side input though. I also can use it as a back-up Battery as well Anyways here are the pics. [ATTACH]30896[/ATTACH] [ATTACH]30897[/ATTACH] [ATTACH]30898[/ATTACH] [ATTACH]30899[/ATTACH] Jeff (the thing behind the Perko Switch is my AMP that I installed about 3 years ago)
GeorgeS Posted May 27, 2009 Posted May 27, 2009 I did the same basic thing on my 89 1st gen. Two Pc-680's, Switched, run either one or both. Works great, Always have 12.7 V to everything, even Ignition system dureing the start sequence.
flb_78 Posted May 27, 2009 Posted May 27, 2009 now get ya a Solar Charger and you'll never have to worry about dead batteries. http://www.walmart.com/catalog/product.do?product_id=10339301 http://i.walmartimages.com/i/p/00/77/55/40/72/0077554072001_215X215.jpg
