Garage door opener
catang5oh
That little circuit it neat but a bit on the costly side. AutoSwitch makes one a lot less expensive. I have one on both of my bikes and have installed it on several friend's bikes. Got mine from Cyclegadgets.com for $38 delivered to my door.. It comes in a positive or negative trigger model so you can use any source you choose. I use the negative trigger from the brake switch. It's more convenient and you do not have to fiddle with the light switch. The brake lever is much easier to use... Tucked the modified remote and the little circuit under the fairing and it works GREAT !!!
