Front brake lever lube?
I've noticed that my front brake lever kind of "catches" as you pull on it, not a smooth pull. Seems to be due to it rubbing on the actuator/plunger in the master cylinder and not having lubrication there. It appears that there is a slight depression or cupping in the actuator where the lever makes contact. I sprayed some dry lube on it and it smoothed out for a couple of days but is back to catching in increments again.
Is this normal and what do you guys use to lubricate that contact point?
Thanks guys. I've got some hi-performance Champion chain "wax" left over from my first ride that I'll try first. Then the lithium since I've got some of it too. Finally, I'll try the synt because it will require a purchase. Thanks for the feedback.
