Guest sparky Posted August 25, 2006 Posted August 25, 2006 2questions. #1 Where is the audio control and cb modules located? #2 My rear shock doesn't hold air very well. Is there a reason for this? I finally got a CD service manual and didn't see a location for the modules or any kind of trouble shooting section in it. any help appreciated. Bill
stardbog Posted August 25, 2006 Posted August 25, 2006 What Kind of trouble with Audio / CB controls you have ? Give us some more infos. Maybe you are looking for Venture user manual. Check out this one: http://www.starmotorcycles.com/star/service/viewmanuals/viewmanuals.aspx?ls=star Good Luck. Dan
BradT Posted August 25, 2006 Posted August 25, 2006 His profile say 1999. The rear shock is a common problem from what I have read. So far I have not had any trouble with mine. Occasionaly my radio acts up, and the CB. Just does not work sometime. I turn the CB on and off and it normally comes back. Appearantly under the fairing there is a plug that requires some dielectric grease to keep the contactors to make proper contact. Brad
stardbog Posted August 25, 2006 Posted August 25, 2006 Audio staf are located inside front fairing, CB unit is under trunk.
Guest sparky Posted August 25, 2006 Posted August 25, 2006 Thanks peeps. I don't know what generation I have. It's a 1999 RSV, so I guess the next ? is, how can u tell?
Wrongway Posted August 25, 2006 Posted August 25, 2006 Thanks peeps. I don't know what generation I have. It's a 1999 RSV, so I guess the next ? is, how can u tell? On the main page , left side menu, check out venture history. 1st gen is 83-93, 2nd gen 99-now. There is some variation and hair splitting but this is generally held to be correct
Snarley Bill Posted August 25, 2006 Posted August 25, 2006 2questions. #1 Where is the audio control and cb modules located? #2 My rear shock doesn't hold air very well. Is there a reason for this? I finally got a CD service manual and didn't see a location for the modules or any kind of trouble shooting section in it. any help appreciated. Bill sparky ,your another one of us lucky ones.you have a good looking, fast, reliable,state of the art,smooth,2nd gen.and if it's black you have it all.bill :rotf: :rotf:
Black Ice Posted August 25, 2006 Posted August 25, 2006 2questions. #1 Where is the audio control and cb modules located? #2 My rear shock doesn't hold air very well. Is there a reason for this? I finally got a CD service manual and didn't see a location for the modules or any kind of trouble shooting section in it. any help appreciated. Bill For the rear shock, this will probably sound stupid but check to make sure the valve stem is tight. Sometimes its the little things that are the problem. The replacement shock I got installed under warranty wasn't holding air well either and when I checked the valve stem it was loose. Once tightened, no more problem with loosing air. Cheers, Gary B
Guest sparky Posted August 25, 2006 Posted August 25, 2006 Mine is sort of gray and silver separated by a goldish pinstripe. It looks fine. I bought it 2 weeks ago and it only had 15,000 miles on if. The dealer said it had never been in the rain.
BradT Posted August 26, 2006 Posted August 26, 2006 Mine is sort of gray and silver separated by a goldish pinstripe. It looks fine. I bought it 2 weeks ago and it only had 15,000 miles on if. The dealer said it had never been in the rain. Nice looking. That is a second Gen definetly. They call it silver but I still think it is green. Brad
Snarley Bill Posted August 26, 2006 Posted August 26, 2006 Mine is sort of gray and silver separated by a goldish pinstripe. It looks fine. I bought it 2 weeks ago and it only had 15,000 miles on if. The dealer said it had never been in the rain. good looking bike looks like it's loaded with extras.bill :)
Guest Brianwgn Posted August 26, 2006 Posted August 26, 2006 you need to put a lot more miles on it now. Brianwgn:080402gudl_prv:
