Squidley Posted October 2, 2006 Posted October 2, 2006 I had posted up a responce on a thread in the watering hole about stopping a crack in your windshield. As far as stopping the crack, you need to get a very tiny drill bit and locate the end of the crack. Take the drill and drill a small hole through the exact point at where the crack ends. In the service we did this to aircraft (called stopdrilling) It relieves the pressure on the crack and stops it from traveling more.
fixit3546 Posted October 3, 2006 Posted October 3, 2006 Plastex makes a clear plastic repair, i've never used it and don't know if it will work but it may be worth a try.
RoadKill Posted October 3, 2006 Posted October 3, 2006 I had posted up a responce on a thread in the watering hole about stopping a crack in your windshield. As far as stopping the crack, you need to get a very tiny drill bit and locate the end of the crack. Take the drill and drill a small hole through the exact point at where the crack ends. In the service we did this to aircraft (called stopdrilling) It relieves the pressure on the crack and stops it from traveling more. Dangerous I know:rotf: When you say locate the end and where the crack ends, in my case since it appears to have started under the bottom trim you are referring to the top of the crack. Right?
Squidley Posted October 3, 2006 Author Posted October 3, 2006 you are referring to the top of the crack. Right? Yes that would also be correct
