VentureRider.Org SuperBrace
Home Venture History Classifieds Links VRAwards VRPhotos VRChat VRStore Donate
Go Back   VentureRider.Org > Technical Library - Read Only > Second Gen and Royal Star Technical Library - READ ONLY! > Computer, Lights, Horns, Other Electrical
User's Login
User Name
Password
Remember Me?
Mini Stats
Members 12,773 Entries 0
Members Entries
Threads 52,398 Reviews 0
Threads Reviews
Posts 624,264 Polls 46
Posts Polls
Content 0 Files 0
Content Files
Links 64 Ads 0
Links Ads
More...
  #1
Old 12-27-2009, 09:12 AM
Freebird's Avatar
Freebird Freebird is offline
ADMIN - 2013 Road Glide Ultra
Freebird has a Profile Picture
Supporting Member
Default Passing Lamp Installation
A big THANK YOU to raceman62race for providing this PDF document for the Yamaha Passing Lamp installation. These are the original instructions from Yamaha that many say do not always come with the lamps.
Most folks here would recommend that you supplement these instructions by adding a relay. Adding a relay will prevent the extra load of the lights from passing through your ignition switch and also isolates the passing lamps from your normal light circuit which would prevent your losing your headlight in the event of a short circuit within the passing lamps.
Here is a simple diagram on wiring a relay for the lamps.
http://www.venturerider.org/forum/showthread.php?t=525
The actual Yamaha instructions are attached here as a pdf file.
Passing Lamp Installation Document
__________________
  #2
Old 10-20-2010, 12:43 PM
etcswjoe's Avatar
etcswjoe etcswjoe is offline
99 RSV Purple & Silver
etcswjoe has a Profile Picture
Supporting Member
Default Lights
Found these two definitions online.
Driving Lights
Driving lights are used to supplement the high beams for greater distance and width; they should be used only in conjunction with the high beams. Aim the centers of the beams at the same level as your high beam tape marks on the wall. Keep in mind that the height requirements vary from state to state, as seen in the chart. In some states it is required that auxiliary lights respond automatically to the fluctuations of the high and low beams. In such cases, alterations to the wiring will be necessary.
As for the horizontal setting of the lights, this is a matter of personal preference. You might prefer lighting the sides of the road at a distance rather than concentrating the majority of light down the middle of the road.
Passing Lights
Passing lights are used to supplement the low beams to provide a more complete and uniform pattern. Aim the centers of the beams at the same level as your low-beam tape marks, or even slightly lower. Again, keep in mind that height requirements vary from state to state. Consult the enclosed chart and your local regulations.
The horizontal setting of the lights is a matter of personal preference. A slight overlap of the beams in the center will give evenly distributed light all the way across the road, as well as very good width. A greater overlap of the beams, on the other hand, will increase the center light and reduce the overall width of the lights.
Original website http://www.drivegreen.com/Auto_Servi...ary_Lights.htm
__________________
Joe
Retired Navy Chief
99 RSV X 2
2006 Ultra Classic
The Following User Says Thank You to etcswjoe For This Useful Post:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Passing Lamp MidlifeVenture Second Generation Venture Tech Talk 19 01-11-2010 05:24 PM
Passing lamp replacement frankc Watering Hole 5 09-09-2009 10:46 AM
Passing lamp installation raceman62race Second Generation Venture Tech Talk 12 07-05-2009 05:56 PM
Passing lamp install Colonel Second Generation Venture Tech Talk 18 01-17-2009 12:44 PM
Passing Lamp installation HELP! royalstarjac Second Generation Venture Tech Talk 4 02-09-2008 06:25 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright 2004 VentureRider.org
