Guest Dave Rogge Posted April 9, 2012 Share #1 Posted April 9, 2012 Hi everyone New guy here. I have an '83 Venture Royale with factory cruise control. I need a new front brake light switch. The one I received from Yamaha has only two wires, while the existing one on the bike has 4 wires, and runs through a small block (resistor or capacitor?) before plugging into a four gang block in the headlight shell. The Yamaha dealer I spoke with couldn't find any reference to the different switch, or a part number for it. Anyone had this same problem?? Link to comment Share on other sites More sharing options...
bongobobny Posted April 9, 2012 Share #2 Posted April 9, 2012 Yes, there are different switches depending on whether you have cruise or not. The second set of contacts on the 4 wire switch is to tell the cruise control controller that the brakes have been applied and to turn off the cruise control. Only the Royale model had the cruise, and the '83 I think was an option. You can try '84 on up for the proper switch. I had an extra but gave it away a couple of months ago... Link to comment Share on other sites More sharing options...
dingy Posted April 10, 2012 Share #3 Posted April 10, 2012 Hi everyone New guy here. I have an '83 Venture Royale with factory cruise control. I need a new front brake light switch. The one I received from Yamaha has only two wires, while the existing one on the bike has 4 wires, and runs through a small block (resistor or capacitor?) before plugging into a four gang block in the headlight shell. The Yamaha dealer I spoke with couldn't find any reference to the different switch, or a part number for it. Anyone had this same problem?? The way you have described the switch, it sounds like an 88-89 one. They put a capacitor/choke in the ones for those 2 years in an attempt to reduce radio noise. The rear brake also has a capacitor/choke, but the clutch does not. Cut of schematic attached. Gary Link to comment Share on other sites More sharing options...
KIC Posted April 10, 2012 Share #4 Posted April 10, 2012 I should have 2 83 parts bikes in a couple of days once I get back from travel. If I have what you need I'll get it to you if you haven't already found one. Let me know. Bill Link to comment Share on other sites More sharing options...
Guest Dave Rogge Posted April 11, 2012 Share #5 Posted April 11, 2012 Yes, there are different switches depending on whether you have cruise or not. The second set of contacts on the 4 wire switch is to tell the cruise control controller that the brakes have been applied and to turn off the cruise control. Only the Royale model had the cruise, and the '83 I think was an option. You can try '84 on up for the proper switch. I had an extra but gave it away a couple of months ago... Thanks for your help! It appears that my switch is from an '89 model like you said. Dave Rogge Link to comment Share on other sites More sharing options...
