Bubba Blue Posted July 31 Share #1 Posted July 31 Is there a reasonable price tach add-on for this model that anyone can recommend? Link to comment Share on other sites More sharing options...
Marcarl Posted August 5 Share #2 Posted August 5 On 7/31/2022 at 8:06 AM, Bubba Blue said: Is there a reasonable price tach add-on for this model that anyone can recommend? I see some have one on the handle bars, hang in there, somebody might even give you directions. Link to comment Share on other sites More sharing options...
videoarizona Posted August 5 Share #3 Posted August 5 Not really. Most of the cheap tachs may not be able to handle the V4. Barons uses a small box to adapt single fire motors. That firing issue may not be adaptable in a cheap tachs so you need to be sure what you are ordering. I'm not an expert on this... Maybe someone else can elaborate. But for me, the biggest issue on my VStar was tach bounce at low tpms. A good tach shouldnt bounce. So I've been hesitant to put a tach on the RSV. Link to comment Share on other sites More sharing options...
XV1100SE Posted August 6 Share #4 Posted August 6 There is a write up in the read only/electrical section for installing a tach. @Carbon_One advised before on one he had purchased off ebay (I got that one but 10 years ago). Baron's is mentioned as having a lot of bounce. The one Larry advised on is stable. Issue to keep in mind of is the spark fires twice...one is a waste burn. 2 Link to comment Share on other sites More sharing options...
