star4772 Posted May 2, 2012 Share #1 Posted May 2, 2012 What would I gain by changing my final drive out in my 2008 RSTD to a V-Max final drive? Also what year would I have to get to do this and is it a straight out change bolt for bolt? Joe and Link to comment Share on other sites More sharing options...
Gary N. Posted May 2, 2012 Share #2 Posted May 2, 2012 Joe, I don't know what the final drive ratio would be but it would be like putting a lower geared rear end in your truck. You get a little more pulling power. Your rpms at cruising speed will be roughly 500 higher. At least that's what I think I've read on here. Might be great if you're pulling a lot of weight like a trailer. Link to comment Share on other sites More sharing options...
GeorgeS Posted May 2, 2012 Share #3 Posted May 2, 2012 Just Down shift, you get about the same effect, ( costs less ) Link to comment Share on other sites More sharing options...
Venturous Randy Posted May 2, 2012 Share #4 Posted May 2, 2012 The difference is 10%. The advantage is you will have more pull in the lower gears and you can also use 4th and especially 5th gear more effectively. If you are now running 3,000 rpm's in 5th gear to maintain 60 mph, the rpm would go up to 3,300 rpm's for 60. On an RSV and especially an RSTD, that would make 5th much more usable and it would probably improve gas mileage. Another thing it may do is reduce the amount of gear whine by riding more in 5th than 4th. I know my 1st gen is quieter in 5th than 4th. RandyA Link to comment Share on other sites More sharing options...
MikeWa Posted May 2, 2012 Share #5 Posted May 2, 2012 I do not know about an RSTD. Check this thread. http://www.venturerider.org/forum/showthread.php?t=69014&highlight=rear+swap Mike Link to comment Share on other sites More sharing options...
flb_78 Posted May 2, 2012 Share #6 Posted May 2, 2012 Lower final drive ratio. Higher RPM's. Easier take off. Easier to pull a trailer. Easier to haul a passenger. Not a direct bolt on. You can either buy one that has been redone. You can buy one and drill the hole for the speed sensor yourself and hope you do not ruin the case. Link to comment Share on other sites More sharing options...
star4772 Posted May 3, 2012 Author Share #7 Posted May 3, 2012 Lower final drive ratio. Higher RPM's. Easier take off. Easier to pull a trailer. Easier to haul a passenger. Not a direct bolt on. You can either buy one that has been redone. You can buy one and drill the hole for the speed sensor yourself and hope you do not ruin the case. Is that all that needs to be done is the hole for speed sensor? That don't seem to hard. Joe Link to comment Share on other sites More sharing options...
OutKast Posted May 5, 2012 Share #8 Posted May 5, 2012 The hole needs to be precise, without getting any shavings into the gears. There is a few on here who have done, but they had access to machining equipment. Link to comment Share on other sites More sharing options...
star4772 Posted May 5, 2012 Author Share #9 Posted May 5, 2012 The hole needs to be precise, without getting any shavings into the gears. There is a few on here who have done, but they had access to machining equipment. Ah ok well maybe I will just nitch the idea unless I can find one all ready done up. Thanks for all the input from everyone. Joe Link to comment Share on other sites More sharing options...
MikeWa Posted May 5, 2012 Share #10 Posted May 5, 2012 If you go to the tech section Freebird posted a complete instruction on changing the pumpkin. It includes a link to purchase the unit all set up and ready to install. If you check out the link I posted above there is also a reference on purchasing the unit ready to install. It is really not all that complicated just check out the links that have been provided to you. Mike Link to comment Share on other sites More sharing options...
