rstacy Posted April 5, 2012 Share #1 Posted April 5, 2012 I have looked and looked and I cant find this screw. I just picked up an 89 and it runs well enough but I swear that it has a lean idle. The previous owner told me that his Yamaha dealer rebuilt the carbs but I don't know what they did or didn't do. I think that they left it too lean. It requires full choke when cold and takes at least 2-3 times as long as my 86 to come off of choke. Also when pulling out from a stop, it requires more throttle and lags a small bit until it gets going. And this is after it is warmed up. Accelerating while moving is laggy for the first 15% of the throttle. I read in a thread that three turns out on the idle screw is a good place to be. Is this a good method or should I just drive the bike to PA to see Earl? Link to comment Share on other sites More sharing options...
rstacy Posted April 5, 2012 Author Share #2 Posted April 5, 2012 PS - I just synced the carbs today. They werent too far off. I also just got a laundry list of things to check from Earl. Thanks Earl! Link to comment Share on other sites More sharing options...
dingy Posted April 5, 2012 Share #3 Posted April 5, 2012 First picture is location of mixture screw, yours may have a brass plug over hole in center of picture. If it does you drill a small hole in brass plug & start a screw in new hole, then pull plug out with screw. 2nd picture shows idle mixture screw in lower right laying on bar. Gary Link to comment Share on other sites More sharing options...
chabicheka Posted April 5, 2012 Share #4 Posted April 5, 2012 Can someone send me a pic of the idle mixture screw? here ya go.....glad to be of assistance. Link to comment Share on other sites More sharing options...
rstacy Posted April 5, 2012 Author Share #5 Posted April 5, 2012 Thanks Gary! Ray Link to comment Share on other sites More sharing options...
