ediddy Posted April 13, 2011 Share #1 Posted April 13, 2011 I can't find a part number for a part. I took the tank off my bike. On the left side there is a black cover that attaches to the neck of the frame. Does anyone know the description and part number? I need the screw that holds this part on the bike. Thanks, Link to comment Share on other sites More sharing options...
Trader Posted April 13, 2011 Share #2 Posted April 13, 2011 what bike, what year? Link to comment Share on other sites More sharing options...
ediddy Posted April 13, 2011 Author Share #3 Posted April 13, 2011 I have an 05 Venture Link to comment Share on other sites More sharing options...
Carbon_One Posted April 13, 2011 Share #4 Posted April 13, 2011 If that's the bolt that also holds the front of the tank in position this this is the part # - 91317-06035-00 The other screw is a plastic push in type. I couldn't find a part number for that one thou. You should be able to take the right side screw to a local hardware store & get a replacement Larry Link to comment Share on other sites More sharing options...
Guest Posted April 13, 2011 Share #5 Posted April 13, 2011 Eddie, just go to an Ace hardware store or Lowes and match up the bolt. I found either store has a good selection of metric bolts there. I got rid on my allen bolts on the tank because they were always rounding out. I have regular hex head bolts in there now. I think they are 6mm bolts. You can also get those push pin screws there too for the front of the cover. Link to comment Share on other sites More sharing options...
ediddy Posted April 13, 2011 Author Share #6 Posted April 13, 2011 Hey CarbonOne and Ruffy, Thanks for the help. Link to comment Share on other sites More sharing options...
