hunter 1500 Posted July 15, 2010 Share #1 Posted July 15, 2010 I had a noise in the rear end and through the tech library I figured out what it was. I had recently changed the rear tire and didn't loosen the bolts on the drive and put the axle in. After doing this and puting it back together I no longer have the noise. Link to comment Share on other sites More sharing options...
GeorgeS Posted July 15, 2010 Share #2 Posted July 15, 2010 I have not seen this point discussed for some time. Good point for new owner's to hear about this. ie: After re-installing the rear wheel, loosen the 4 nuts on the pumpkin, and the Axel nut, then Tap Tap Tap on every thing with a rubber mallet, to relieve any " STRESS " built up in the assembly, then re-torque everything in about 4 steps. ( after everything has been cleaned and greesed, of course ) Link to comment Share on other sites More sharing options...
