GolfVenture Posted March 16, 2012 Share #1 Posted March 16, 2012 I just purchased a Chrome Radiator Grill from ebay and learned that I need spacers for correct installation. Was wonder if someone with one of these might remove a spacer and post the diameter and thickness of the spacer. There is a Mclendons Hardware store near by and they have all sorts of spacers in various sizes. I would also think that a Nylon Spacer would work for it would be far enough away from the Radiator heat. If I can't find the exact size I might be able to find one long spacer and chop saw it to the specific length. Link to comment Share on other sites More sharing options...
bongobobny Posted March 16, 2012 Share #2 Posted March 16, 2012 The spacers come out to just past the side radiator covers if that helps you out any. In a pinch you can use a large nut or stack some washers... Link to comment Share on other sites More sharing options...
dingy Posted March 16, 2012 Share #3 Posted March 16, 2012 Standard radiator cover is 14 15/16" inside at mounting boss points. Ventureline radiator is 15 3/4" +/- at inside mount points. This can flex some so don't hurt yourself getting down to .005". It can probably flex an 1/8" on each side. Its bendable aluminum. Got this one from Bongo a few years ago, it has had a face lift & powder coated. Gary Link to comment Share on other sites More sharing options...
