Roadflyer Posted August 23, 2019 Share #1 Posted August 23, 2019 Can it be done? how hard is it? Link to comment Share on other sites More sharing options...
Rafterd Posted August 23, 2019 Share #2 Posted August 23, 2019 Can it be done? how hard is it? I wouldn't think so. Personally, I wouldn’t even try. The engine is not that hard to pull. Link to comment Share on other sites More sharing options...
djh3 Posted August 24, 2019 Share #3 Posted August 24, 2019 From my experience doing just a valve adjustment, I would say not. It was all I could do to get valve cover off. If studs come up thru heads, you wont have enough room to go up and over. Link to comment Share on other sites More sharing options...
Roadflyer Posted August 24, 2019 Author Share #4 Posted August 24, 2019 From my experience doing just a valve adjustment, I would say not. It was all I could do to get valve cover off. If studs come up thru heads, you wont have enough room to go up and over. Thanks for the info. Looks like I will be pulling the motor. Link to comment Share on other sites More sharing options...
baylensman Posted August 26, 2019 Share #5 Posted August 26, 2019 I did it on the 96, i order to replace the head gasket. One of the top rails actually unbolted and allows to lift the front head out. Watch the dang timing chain and cam alignment markers when reinstalling, did mine 3 times as the shop manual was a bit unclear. Don't know if and when the frame changed probably can looks it up online somewhere. Link to comment Share on other sites More sharing options...
Rafterd Posted August 26, 2019 Share #6 Posted August 26, 2019 A 96 Venture?? Hmmmm Link to comment Share on other sites More sharing options...
