bmannon Posted September 5, 2008 Posted September 5, 2008 are these mufflers direct bolt on replacements for a first gen? http://www.macperformance.com/store/category.cfm?SID=3&Category_ID=912&Catlevel=3 wondering because it says they fit ''all models''
Condor Posted September 5, 2008 Posted September 5, 2008 are these mufflers direct bolt on replacements for a first gen? http://www.macperformance.com/store/category.cfm?SID=3&Category_ID=912&Catlevel=3 wondering because it says they fit ''all models'' Pretty much a direct bolt on. You'll need to swap out the bolts to shorter ones, and mess around a bit getting them on, but they're made to replace the OEMs.
bmannon Posted September 5, 2008 Author Posted September 5, 2008 Pretty much a direct bolt on. You'll need to swap out the bolts to shorter ones, and mess around a bit getting them on, but they're made to replace the OEMs. OK Thanks, I was looking at the originals that are on the bike and it looks like the have a bend in them, and I wasnt sure if that was built into the muffler or if it is a seperate piece.
Condor Posted September 5, 2008 Posted September 5, 2008 OK Thanks, I was looking at the originals that are on the bike and it looks like the have a bend in them, and I wasnt sure if that was built into the muffler or if it is a seperate piece. All one piece....
bmannon Posted September 5, 2008 Author Posted September 5, 2008 All one piece.... So just to clarify, the Macs have the bend in them also?
Condor Posted September 5, 2008 Posted September 5, 2008 So just to clarify, the Macs have the bend in them also? Yes...... if they didn't have a bend they wouldn't be slip-ons........
bmannon Posted September 5, 2008 Author Posted September 5, 2008 Yes...... if they didn't have a bend they wouldn't be slip-ons........ Thanks a lot for the responce, I just wanted to make sure before I ordered a set because if I had to fab up a bend I was just going to get some of the super cheap turn downs that JC Whitney sells.
Condor Posted September 5, 2008 Posted September 5, 2008 Thanks a lot for the responce, I just wanted to make sure before I ordered a set because if I had to fab up a bend I was just going to get some of the super cheap turn downs that JC Whitney sells. No Problem. Check the link out. http://www.venturerider.org/forum/showthread.php?t=22324
bmannon Posted September 5, 2008 Author Posted September 5, 2008 No Problem. Check the link out. http://www.venturerider.org/forum/showthread.php?t=22324 sent you an e-mail about those extra sets you have....
