Venturous Randy Posted April 16, 2007 Posted April 16, 2007 I have a set of six coils off a Nissan Maxima engine that have the coils right on top of the sparkplug boot. I was wondering that if they would fit on top of the plugs on my bike, could I bypass the coils I have and run the respective wire that goes to the coil to the spark plug coil. I believe they only require a hot wire and a ground wire. Has anyone done this? I don't see why it would not work if the room in the plug area is suffient. Any comments? RandyA
Denden Posted April 16, 2007 Posted April 16, 2007 If the coil primary resistance isn't correct, you run the risk of frying your TCI. Primary side resistance should be 2.7 ohms +/- 10%. Secondary side resistance for stock is 13.2 k ohm +/- 20%. But I'm not real sure the secondary resistance would have any affect on the TCI. But make sure the primary side is in the range.
Venturous Randy Posted April 16, 2007 Author Posted April 16, 2007 Thanks Dennis, It would probably be a fluke if the primary side was near the correct range, but I will check it out. These things may not even fit into the required area. I will let you know what I come up with. Thanks, RandyA
