labill Posted July 2, 2008 Posted July 2, 2008 I just put on 1 1/4 risers. Now I don't have any turn signals. Fuse is not blown. Throttle also is slow to return to idle when released. Horn, lights work. I tried to open up the signal, light and horn assembly to see if I pulled the wires loose. Took out the bolt in rear but can't get the cover off. Any suggestions on where to look or what to try. Thanks, labill
Gary N. Posted July 2, 2008 Posted July 2, 2008 You must of pulled something loose. And your throttle cables are definitely too tight. You need to get behind the fairing and snip some ties or re-route the throttle cables. Don't try and drive it like that.
labill Posted July 2, 2008 Author Posted July 2, 2008 Gary, Thanks. Might just remove the risers instead of removing that faring. labill
RoadKill Posted July 3, 2008 Posted July 3, 2008 The fairing is not that hard. I think all you would need to remove is the front. In our Tech section their is a good article showing exactly how. Think its under AUX splliter install. Even I did it, so it has to be easy
