Steve S Posted 3 hours ago #1 Posted 3 hours ago Hello Venture Crew. I rode the Venture last week and noticed some coolant dripping on the ground after riding for an hour. (Really thought I had a leaking radiator hose.) I finally got around to checking for the problem yesterday and found the leak was coming from the radiator drain plug. I put a wrench on it to tighten it, and the head of the plastic plug broke off. Thankfully I had a left-hand drill bit and was able to spin the threaded part out without any problems. A new one has been ordered, and I will be able to ride it to Vogel next week.
RDawson Posted 2 hours ago #2 Posted 2 hours ago 45 minutes ago, Steve S said: Hello Venture Crew. I rode the Venture last week and noticed some coolant dripping on the ground after riding for an hour. (Really thought I had a leaking radiator hose.) I finally got around to checking for the problem yesterday and found the leak was coming from the radiator drain plug. I put a wrench on it to tighten it, and the head of the plastic plug broke off. Thankfully I had a left-hand drill bit and was able to spin the threaded part out without any problems. A new one has been ordered, and I will be able to ride it to Vogel next week. Steve if you have trouble getting it in time let me know. I have a radiator off a bike I junked. I just checked and it came out easily.
